ACRC 100 float switch condensate pan
  • ACRC 100 float switch condensate pan
5060
142
Posted: ‎2021-06-28 12:03 AM . Last Modified: ‎2024-03-18 11:43 PM
802
I am producing a lot of condensate can and our float that raises up to open condensate to drain sticks closed from time to time - all is gravity fed so I don't need to pump it up and out - can I prop open that drain float valve so it drains all the time?
  • DCX
  • wmb
Hello Chris. The float in the condensate pan on the ACRC100 controls the condensate pump that is within the unit, to pump the water out of the condensate pan. I would not recommend propping this up as it will make the condensate pump run constantly. This will burn out the condensate pump very quickly.
Thank you
Thank you
