  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
8832 PDUs not getting an IP address via DHCP
  • Communities
  • Re: 8832 PDUs not getting an IP address via DHCP
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
darrell_apc
darrell_apc
Posted: ‎2021-07-09 04:38 AM
1260
This was originally posted on APC forums on 2/15/2018
Just got 4 8832's and am trying to get them on the network. They have link, with flashing amber, but are not able to obtain a dhcp address. Sniffing packets, I don't even see a DHCP attempt. They try for IPv6, but I'm not using it on this network segment. Other devices on this network are able to obtain addresses. They are running 6.4.6, and I've cleared and check configs multiple times, as well as trying 6.4.4, no luck. SHOWS P+ N? A+ (after turning off ipv6 to test, N4? N6+ when it's enabled and has obtained a link local IP). Networking works when configured manual, but I'd really prefer DHCP.
Any ideas or things to try?
  • Racks, Rack Accessories, & Cooling
This reply was originally posted by Angela on APC forums on 2/23/2018
Hi Darrell,
Yes, we can advance replace. I will contact you via private message here in order to proceed with next steps.
Replies 5
This reply was originally posted by Angela on APC forums on 2/16/2018
Hi Darrell,
I'd try a "format" to factory reset the PDUs, assuming these were already just new with no configuration them to lose.
To do this, hold down the pinhole reset button that is on the display. You'll want to hold it for 20+ seconds. It will flash quickly green and then switch to orange/amber when you can let go. Then, it will reboot the management interface and then re-try.
Alternatively, in the console, you can check first by entering 'tcpip' command  with no options to make sure it says IPv4: enabled (as opposed to disabled). Also enter the 'boot' command to make sure it says DHCP is actually enabled for IPv4 and that APC Cookie is NOT required.
Sorry, those suggestions are a little backwards embarassed
Hopefully one of them gets you further in getting DHCP to work.
darrell_apc
darrell_apc
This was originally posted on APC forums on 2/16/2018
Tried the pinhole reset, and a 'format' command, no changes. Definitely set for dhcp and no cookie (and my dhcp server has the cookie configured). Still odd that I don't even see an attempt on the wire, don't know what's up with that.
We manually configured them and they are working that way, but not optimal for us, for sure.
Hmm, I have seen something similar once before but never got to the bottom of it. It was on one of the UPS Network Management Cards and it was only a single card as well. But I don't believe IPv4 worked at all.. you got it working on manual IP at least. I recall only seeing IPv6 working in my scenario as well no matter what I did.
If you're interested and I assume these would be in warranty, we could always try to arrange replacing one of the display modules for you in one of the PDUs which includes the network management card module in it. I could also have you return the display to me directly to look at it and the configuration and see if I can pinpoint the problem.
Let me know.
darrell_apc
darrell_apc
This was originally posted on APC forums on 2/22/2018
Had to check up with my facilities guys, but it turns out we did buy these new recently, so we should be under warranty.
I've definitely got the same scenario here, IPv6 works fine, but IPv4 doesn't and I happen to need v4. Can you advance replace the part? We've got these 4 in production with static configs now, so I'd need to get the part in before I sent one back.
Hi Darrell,
Additional options
