Properties description
Working with the equipment browser (desktop client)
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • Working with the equipment browser (desktop client)
  • Properties description
  • Mark as Read
  • Filtering and finding equipment in Equipment Brows...
  • Exporting Equipment Browser table
  • Editing IP address through the Equipment Browser
  • Creating predefined table configurations
  • Editing multiple items in the Equipment Browser
EcoStruxure IT Support
Request Support
Back to Working with the equipment browser (desktop client)
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
Asset properties available in IT Advisor
When working with the equipment browser, you have the option to specify which columns are shown in the equipment browser (Configure columns 102237522_360037995294.png102237522_360037995294.png). The dialog box used for specifying columns displays a number of properties along with a description. This page adds to these descriptions.
Property
Description
Can be found in... Optional/Auto entered License
Account No Customer specific information Customer Properties Customer data integration Co-lo
Area (m2) Area occupied by rack or cage Physical Properties (rack) Calculated by ITA Co-lo
Available Power Outlets
The amount of available power outlets on rack PDUs in the rack. The amount of power outlets is set in rack PDU Power Properties.
The system subtracts the amount of configured power connections.
Power Properties Calculated by ITA Capacity
Average CPU Utilization (%) Average CPU utilization seen at device discovered by external system over the last 30 days IT Optimize tooltip ITO integration IT Optimize
Average Inlet Temperature Average inlet temperature seen at device discovered by external system - ITO integration IT Optimize
Average Power Utilization (W) Average power utilization seen at device discovered by external system over the last 30 days IT Optimize tooltip  ITO integration IT Optimize
Barcode
The asset's barcode. Must be unique
General Properties
Optional
Operation
Bay count The amount of bays in a blade or modular switch enclosure Physical Properties (Genomes) Genome Library
Operation
Bay type The bay type (half or full) of a blade or modular switch component Physical Properties (Genomes) Genome Library Operation
Company Customer specific information Customer Properties Customer data integration Co-lo
Connection State Defines if the device is online, offline, or not responding. External Systems Properties (read) DCE integration / ITO Operation / IT Optimize
Contact Customer specific information Customer Properties (read) Customer data integration Co-lo
CPU Type The asset's CPU data External Systems Properties (read) ITO integration IT Optimize
Description A description of the equipment General Properties Pre-entered Operation
Device description Description of device transferred from DCE server DCE server DCE integration Operation
Device IP Address IP address of device discovered by external system External Systems Properties (read) DCE integration / ITO Operation / IT Optimize
Device Location Location of device transferred from DCE server DCE server DCE integration Operation
Device Manufacturer Manufacturer of the discovered device reported from the device. External Systems Properties (read) ITO integration IT Optimize
Device Model Name Model of device discovered by external system External Systems Properties (read) DCE integration / ITO Operation / IT Optimize
Device Name Name of device transferred from DCE server DCE server DCE integration Operation
Discovery Protocols The protocols used to discover the device -  ITO integration IT Optimize
Discovery Time The first time the device was discovered External Systems Properties (read) ITO integration IT Optimize
Estimated Load (W) or Adjusted Nameplate The actual maximum power consumption of the asset Power Properties Pre-entered Operation
Floor Coordinates Coordinates on floor based on sequence or customization Floor Properties Optional
Operation
Group Name of group in which device is located in DCE DCE server DCE integration
Operation
Hostnames Hostname of device discovered by external system External Systems Properties (read) DCE integration / ITO Operation / IT Optimize
Idle Power (W) Power draw of device when inactive - ITO integration IT Optimize
Installation Date Date where asset is installed General properties Auto entered when asset is added Operation
IP Address IP address of device Network properties/Network Management Optional Operation
Last Poll Time When was the device discovered by external system poll last time - ITO integration IT Optimize
Location Location of device General properties (read) ITA Operation
Manufacturer Manufacturer of asset. General properties Genome library Operation
Manufacturer's Nameplate (W) The default nameplate value of a asset Power properties Genome library Operation
Max Power (W) The maximum power usage of the device. Data coming from verified power profile in Genome. Power properties (read) ITO integration IT Optimize
Max Power Ports Total number of power outlets in rack. A summation of power outlets on rack mount PDUs in a rack. Power properties Calculated by ITA Operation
Model Name Model of device General properties Genome library Operation
Module Type The type (single or double) of a blade or switch module Physical Properties (Genomes) Genome Library Operation
Name
Name of device, could be used for more telling names than model name General properties Optional Operation
Operating Systems Operating system of device discovered by external system External Systems properties (read) ITO integration IT Optimize
Parent System The type of external system from which IT Advisor is retrieving device/asset data. External Systems properties (read) External system Operation
Part Number Part number of device General properties Genome Library Operation
Peak CPU Utilization (%) Maximum CPU utilization seen at device discovered by external system over the last 30 days -  ITO integration IT Optimize
Peak Inlet Temperature Maximum inlet temperature seen at device discovered by external system
Peak Power Utilization (W) Maximum power utilization seen at device discovered by external system over the last 30 days -  ITO integration IT Optimize
Phone Number Customer specific information Customer properties (read) Customer data integration Co-lo
Port Description The entered descriptions of the network equipment's port configurations Network Properties/Network Management Optional Operation
Power Profile Power profile being used External Systems properties (read) ITO integration IT Optimize
Power Profile Enabled Once device is discovered by IT Optimize server the power estimated load is taken from the power profile Power properties ITO integration IT Optimize
Power Sold (kW) Customer specific information Customer properties Optional Co-lo
Product Family The product family of a blade or modular switch component Physical Properties (Genomes)
Genome Library
Operation
Rack The name of the rack, or the name of the rack in which the equipment is located.
General properties
Optional Operation
Redundancy The redundancy option of the equipment Power properties Manuel entered Capacity
Room The room in which the equipment is located. General properties
Manual entered
Operation
Row The row in which the equipment is located. General properties
Auto entered when row is added
Operation
Serial Number Serial number of device discovered by external system External Systems properties (read) DCE integration / ITO Operation / IT Optimize
Server Access Enabled Server access enabled on device Server Access Properties ITO integration Server Access
Stage Equipment is Existing by default. Planning stages, such as Pending Move will be seen if change module being used Work order Auto entered by system Change
State State of device discovered by external system External Systems properties (read) DCE integration / ITO Operation / IT Optimize
Supports Power Capping The device supports the power capping functionality Configure Power Capping menu on rack ITO integration IT Power Control
Supports Remote Console Remote console supported by device Server Access Properties ITO integration Server Access
Type Type of device discovered by external system External Systems properties (read) DCE integration / ITO Operation / IT Optimize
U-Height The amount of U-positions occupied by the equipment Physical properties (Genomes) Genome Library Operation
U-Position The U-Position where equipment is located General Properties (read) Genome Library Operation
Virtual Machines and Templates Specifying virtual machines and templates of discovered VMware system External Systems properties (read) VMware integration Capacity
Weight The equipment's physical weight Physical properties Genome Library Operation
Zero-based numbering Enclosure's bay numbering starts from 0 Physical properties Genome Library Operation
<Custom property> Customer specified property. Properties (Custom) Optional Operation
Tags
Contains a list of names of tags
Tags properties Optional Capacity
Tag <#>
Shows a given tag <#>
Internal breaker derating Rack PDUs internal breaker derating Power properties Manuel entered Capacity
U-Positions from bottom Rack U-Positions counted from bottom to top Physical properties Genome Library Operation
U-Positions from 0 Rack U-Positions counted from 0 Physical properties Genome Library Operation
