Working with the Genome Library and genomes
Send InviteCancel
IT Advisor includes a built-in Genome Library and a customizable list of genomes to use in your data center infrastructure.
Genome Library
The Genome Library is a read-only collection of available products you can select from and add to the customizable list of genomes to use in your data center infrastructure, provided you have the necessary user rights.
The Genome Library database is extended with thousands of additional measured server power profiles, storage and switch specifications, and much more. This continuously growing asset library enables IT Advisor to determine power consumption without the aid of hardware sensors.
You can open the Genome Library and drag and drop equipment directly into your customizable list of genomes.
Genomes
Genomes is an editable list of selected products you can use in your data center infrastructure.
You can right-click to add, rename, or delete categories and to copy or delete products. Multiple users can apply changes to the genomes at the same time.
The Genomes pane lists all available equipment and allows you to add floor and rack-mountable equipment to a rack or any type of room. Dynamic search allows you start typing in the Search box, the list shows all equipment that contains the typed characters.
Creating the list of Genomes
Configure the list of genomes to contain the floor and rack-mountable equipment to add to the data center infrastructure.
Adding categories and products
Select Planning>Data Center in the Application bar.
Access the Genome Library through Tools > Open Genome Library or the Open Genome Library icon in the Toolbar.
Drag and drop a product or category from the library to the Genomes pane (or right-click and select Add to Genomes). The products are placed in the same structure as in the library.
If you need a new sub category, right-click a category in Genomes and select Add category.
Editing categories and products
Right-click a category in Genomes to add, rename, or delete categories.
Right-click a product to copy or delete products.
Drag and drop products and categories if you want to restructure the list.
If a product does not exist in the Genome Library...
For example, use the Generic Switch Enclosure and Generic Switch Module to configure a modular switch that does not exist in the Genome library yet or a Generic Rack to configure a non-standard size rack, such as half size.
To add a half size rack:
Right-click a Generic rack type in Genomes.
Select Properties and modify the size, name, etc.
Requesting support for a not yet supported product
You can request support for any products in your data center that you cannot currently find in the Genome Library.
Fill in the request form, adding details about the device, such as type, model, vendor.
