Troubleshooting inaccurate 3D calculations
Working with the 3D temperature map
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Working with the 3D temperature map
  • Troubleshooting inaccurate 3D calculations
  • Mark as Read
  • Customizing 3D Colors and Thresholds
EcoStruxure IT Support
Request Support
Back to Working with the 3D temperature map
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
You may experience unexpected calculations in your 3D layout due to specific configurations not currently supported in 3D.
If your solution includes deactivated cooling units for failure simulation, the decrease in cooling capacity is not reflected in 3D as this is currently not supported.
Workaround
You can omit the airflow of a cooling unit in 3D in one of these ways:
  • Change the airflow and cooling capacity of the cooling unit to 0 (by right-clicking and selecting Properties; remember to note the value first to be able to restore it after the failure simulation)
  • Moving the cooling unit outside the room
  • Deleting the cooling unit (not recommended unless you are working with a test setup and perform a backup first)
