Customizing 3D Colors and Thresholds
Working with the 3D temperature map
Send InviteCancel
In the 3D view, you can customize the temperature range by adjusting the thresholds for maximum and minimum temperature. You can also customize the colors of the temperature scale.
1. Access the thermometer settings by clicking the icon at the bottom of the thermometer in the 3D layout.
2. Customize the thresholds for minimum and maximum temperature in the temperature range by typing the wanted degrees.
3. Customize the colors for the temperature range by selecting the 5 color icons one by one and defining the color range to apply.
If you regret the color selection, you can select to reset to use the default colors.
Tip
Tip: If the thermometer does not show, click the arrow icon to invoke it.
To customize the graphical representation of the velocity arrows, use the settings in Tools>Preferences>Temperature Map.
These settings define how the arrows will indicate the velocity in the 3D Velocity plane. The different velocities will be represented as arrows of a certain length or color.
