Power profiles and power value accuracy levels
Viewing external system data
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • Viewing external system data
  • Power profiles and power value accuracy levels
  • Mark as Read
  • The importance of system time synchronization for ...
  • Launch to device in ITA
  • How removing a server affects power values
  • Associating live data from an external system to t...
  • About peak and average power data retrieval from D...
EcoStruxure IT Support
Request Support
Back to Viewing external system data
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
IT Advisor operates with these power values when calculating the most accurate values based on the data retrieval from external systems and product specifications.
In the application, power values are highlighted based on the accuracy levels:
Green
Advanced
Yellow
Nameplate and Basic
Red
No genome match
Advanced
Server Centric (Identical Match)
A power profile where the discovered server matches a server we have measured and the CPUs in the machine discovered matches the CPUs of the machine we have measured. This gives a non-linear power curve.
CPU Centric (Component Based Model)
A power profile where the discovered server matches a server we have measured, but the CPUs in the machine discovered do not match the CPUs of the machine we have measured.
However, the CPUs in the discovered machine do match a CPU we have measured. This gives a non-linear power curve.
Soft Profile (Identical non-measured Model)
A power profile where the discovered server matches a server for which we have vendor calculator information. This gives a non-linear power curve.
Basic
CPU Centric Auto-Derated Nameplate (Component Based Model)
However, unlike the CPU Centric case we have not measured the CPUs in the discovered server, but have a TDP nameplate value for the CPUs in the discovered server. This gives a flat power line much better than a spec nameplate value for the server.
Nameplate
A power profile where the discovered server does not match a server we have measured. This gives a flat power line representing the vendor provided spec value.
