Launch to device in ITA
Viewing external system data
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • Viewing external system data
  • Launch to device in ITA
  • Mark as Read
  • The importance of system time synchronization for ...
  • Power profiles and power value accuracy levels
  • How removing a server affects power values
  • Associating live data from an external system to t...
  • About peak and average power data retrieval from D...
EcoStruxure IT Support
Request Support
Back to Viewing external system data
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
You can access the device ITA web interface directly from the Launch to Device right-click option.
  1. Right-click a device, in the Unassociated Devices pane, for example, and select Launch to Device.
    An error will occur if the HTTP/HTTPS protocol or port definitions defined for this device at the external system server do not match the protocol and port definitions required by that device.
  2. If an error occurs, refer to the external system's documentation for instructions on how to check or set the HTTP/HTTPS settings.
