Create a Template action
Templates
  • EcoStruxure IT Help Center
  • DCE configuration
  • Templates
  • Create a Template action
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Templates
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Use a monitored APC SNMP device's settings to create a template that can be used to configure monitored APC SNMP devices.
  1. Select Create a Template, and click Next.
  2. Use the "Select Configuration Source" display to select the APC SNMP device you want to use as the template source, and click Next.
  3. Use the "Configure Device Settings" display to select, and edit, as needed, the settings you want to store in the template, and click Next.
  4. Use the "Save Configuration Template" display to name the template, and to save it when you click Finish.
