ftp full with 35Mb
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • ftp full with 35Mb
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2014-08-18 12:49 AM . Last Modified: ‎2024-07-15 12:06 AM
633
ftp full with 35Mb
Is it possible to allow ftp to use the free space in micro memory card?
Now is using another space and reaches full with more or less 35Mb.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
sesa299442
sesa299442 Schneider Alumni (Retired)
Posted: ‎2014-08-18 03:56 AM
There is  new application note going to be released, which describes the procedure more in detail.
The release will be soon. So keep checking updates on this forum.
Here is a small hint from the upcomming application note:
  1. Format your flash drive in NTFS – in “My computer” by right click and format
  2. Update USB start up script to:
-- create usb mount directory
  • os.execute('mkdir -p /mnt/usb')
-- find first matching usb storage device
dev = io.readproc('ls /dev/sd*1 2>/dev/null'😞match('/dev/sd%l1')
-- found it, mount
if dev then
    os.execute('mount '.. dev ..' /mnt/usb')
    os.execute('mkdir -p /home/ftp/usb')
    os.execute('mount /mnt/usb /home/ftp/usb')
  os.execute('chown ftp:ftp /home/ftp/usb')
    alert('[usb-mount] mounted %s', dev)
-- nothing found, local flash will be used
else
    alert('[usb-mount] no device found')
end
  3. Reboot homeLYnk
Now can be read/write to USB flash drive via FTP client.
Regards
Tomas
sesa299442
Posted: ‎2014-08-18 02:30 AM
598
It is possible to use USB flashdisk to extend your ftp accessible space.
esteve_budia
Lieutenant
Posted: ‎2014-08-18 03:23 AM
598
How?
sesa299442
-- found it, mount
if dev then
else
end
  3. Reboot homeLYnk
Regards
Tomas
