Wiser for KNX
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Wiser for KNX
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Elettrosecurity
Crewman Elettrosecurity
Crewman
Posted: ‎2025-06-04 07:48 AM
570
Wiser for KNX
hi,
i am new in SpaceLogic forum,
i have a problem with wiser, in FBeditor i have to invert the input of a logic AND but i can't find how to invert the input.
Can you help me?
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2025-06-18 04:27 AM
504
Hello Elettrosecurity!
Sorry for the late reply first of all!
To be honest with you ... I am not a fan of the function block editor.
Why? I prefer always the scripting as it is much more obvious and flexible.
So maybe I can invite you to test the scripting functions as your topic is a nice stepin.
I created 3 group addresses (InputA, INPUTB, OUTPUT) within W4K with the Datatype Boolen 01.002.
I linked the INPUT-Objects with a Tag called NAND.
Then you go in the section "scripting" and you create a new event script by using the Tag NAND.
In the script you enter the following code:
InputA = grp.getvalue('32/1/13')
InputB = grp.getvalue('32/1/14')
if InputA and InputB then
  grp.write('32/1/15', true)
else
grp.write('32/1/15', false)
end
Here you need to adapt the group addresses according to your config.
Save and activate the script.
If you have done everything correctly, then you see how easy it is to create a first script with an AND logic.
If you want now to have the inverted output, you simply change true/false within the IF condition.
Does it work? Please let me know!
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
505
else
end
Kind regards
Thomas
Elettrosecurity
Crewman
Posted: ‎2025-07-02 12:36 PM
Hello Thomas, thanks for your solution, i have solved with: address link to OR with output not , this output is linked to AND logic.
Kind regards
Stefano
Elettrosecurity
