Where can I get the firmware V2.1 for the DALI Gateway Pro?
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Where can I get the firmware V2.1 for the DALI Gateway Pro?
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Waldmops
Waldmops
Cadet
Posted: ‎2024-12-16 08:52 AM
1452
I am looking for the firmware V2.1 for the Dali Gateway Pro. I already have the ETS application 2.1 and the DCA 2.1, but I can no longer programme the gateway now. The latest firmware on the homepage/DFU is 2.0.2, although I can also find release notes and instructions for 2.1.
Is the DFU download archive wrong here?
  • Documents
  • SpaceLogic devices
Heribert_Dölger
Commander
Posted: ‎2024-12-17 12:37 AM
Hello Waldmops
The firmware is shortly before being published. It is just a matter of a few days. Please find the FW files attached.
Space_Logic_KNX_DFU_Firmware_00_46 2.zip
Replies 5
Heribert_Dölger
Commander
Hello Waldmops
Waldmops
Waldmops
Cadet
Posted: ‎2024-12-17 01:12 AM
Thank you!
For others as a note: For a successful update you have to rename the zip and cms file to ‘SpaceLogic_KNX_DFU 00_46’.
Heribert_Dölger
Commander
Posted: ‎2024-12-17 02:55 AM
Many thanks for the hint!
Heribert_Dölger
Commander
Posted: ‎2024-12-17 06:27 AM . Last Modified: ‎2024-12-17 06:28 AM
Here is a corrected version with proper naming.
Space_Logic_KNX_DFU_Firmware_00_46.zip
Alejandro_llg
Alejandro_llg
Cadet
Posted: ‎2024-12-31 06:27 AM
Thank for upload update firmware, funtion perfect.
