Weather station programming
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Weather station programming
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
FZetina
Commander FZetina Commander
29
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
mostafa_ramadan
Ensign mostafa_ramadan
Ensign
Posted: ‎2024-06-13 02:58 AM . Last Modified: ‎2024-07-14 11:38 PM
2162
We need to control facade lighting (Dali Value) with weather station MTN682991 and brightness sensor MTN663593.
I select brightness sensor as sensor type (as attached pic.1)
now how to program Dali value object to this sensor input.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2024-06-25 07:54 AM
Hello Mostafa_ramadan,
if you are familiar with scripts ... you can try the following one.
It reacts simply on the normal Lux output (shown in your picture under the section "General").
In case the brightness is under a certain level (in my example 100 Lux), then the DALI-Brightness will be slowly increased. When it is completely dark then the brightness goes to 100%. See attached video.
This works the other way arround also.
With the given requirements ... this would be my first approach. What do you think about it?
Here the script which reacts on each Lux-Level-Update.
-- Get actual Lux-Value
Lux_Value = event.getvalue()
-- Definition of DALI-Brightness-Value Group-Address
DALI_GA = '35/1/2'
-- If Lux-Value
if Lux_Value > 100 then
-- Greater then 100 then switch off (0%), if not already done
grp.checkwrite(DALI_GA, 0)
else
  -- Lower then 100 Lux
  DALI_Value = 100 - Lux_Value
grp.checkwrite(DALI_GA, DALI_Value)
end
Kind regards
Thomas
Application Design Engineer
Replies 11
Heribert_Dölger
Commander
Posted: ‎2024-06-13 09:01 AM . Last Modified: ‎2024-06-13 09:02 AM
Hello
With the settings sccording your screenshot you will get 3 communicaiton objects: measured lux value, and two 1-bit objects for threshold 1 and threshold 2. The thresholds objects you can use to switch on and off the light.
Not sure if I have understood correctly what you want to achieve. If my answer doesn't help you please give some further details what exactly and how you want to control the DALI light.
mostafa_ramadan
Ensign
Posted: ‎2024-06-22 11:57 PM
I need to control lighting Intensity depend on measured lux value from sensors.
Erwin-vd-Zwart
Janeway
Posted: ‎2024-06-23 11:17 PM . Last Modified: ‎2024-06-23 11:26 PM
@mostafa_ramadan
Normally lighting control is calculated in a sensor like a MTN630919 that is holding an calculation function for this, the sensor you have now doesn’t have that function, you can only use the brightness as a threshold and switch something within the set limits.
But i don’t recommend to use a weather station anyway as normally with constant light control you measure the conditions in the room including reflection and not an outside measurement that is not representing the desired 500 lux in a room itself.
Just my 50ct..
Thomas_Rohde
Sisko
Posted: ‎2024-06-24 12:03 AM
2081
quick question ...
Do you have a Wiser for KNX (LSS100100) or a spaceLYnk within your installation?
Kind regards
Thomas
Erwin-vd-Zwart
Janeway
Posted: ‎2024-06-24 12:24 AM
Hi Thomas, i thought about this option and yes you can make script with certain thresholds to make a mapping with outside measurement 30.000 -> 50% output to DALI or whatever but i don’t think this will ever function properly as you don’t know the room conditions..
However this could be a “quick and dirty” implementation i would not recommend to go that way….
Thomas_Rohde
Sisko
Posted: ‎2024-06-24 11:20 PM
2047
Hi Erwin,
maybe I missunderstood something but I do not understand "room conditions"?
The question is "We need to control facade lighting (Dali Value) with weather station MTN682991 and brightness sensor MTN663593." ... or?
In my understanding he needs to iluminate the facade (outside) of a certain building.
But maybe I am wrong with it. @mostafa_ramadan , please correct me if I am wrong.
Kind regards
Thomas
mostafa_ramadan
Ensign
Posted: ‎2024-06-25 02:36 AM
2038
Hi @Thomas_Rohde,
You are right I need to control outside facade dali fixtures and yes we have spacelynk and AS-P in project.
Thomas_Rohde
Sisko
DALI_GA = '35/1/2'
-- If Lux-Value
else
end
Kind regards
Thomas
Thomas_Rohde
Sisko
Posted: ‎2024-07-08 06:40 AM
does it work, or did you found another solution?
Kind regards
Thomas
DkShree
Crewman DkShree
Crewman
Posted: ‎2025-07-25 08:28 AM
868
hello
@Thomas_Rohde sir
thanks for your script for lux to Dali lights group. you script I have added in our controller (lss100100) working fine and this script inversely proportional to Light Brightness.
here sir I want to add some our requirements for our experience center .
1. if lights lux value between 4000 to 5000 then this scene will trigger or for evening if lux value 500 to 400 then this scene will trigger. i have make number of scenes all scenes working with time like 5 pm 6am and lunch 2 pm. but I want to control from lux value for lux I have installed weather station.
2. if outer temperature or between 27'c to 25'c then following ac will ON and set temperature to 24'c
sir can you please share some script for above requirements this will be very helpful for our experience center
thanks
Dinesh Kumar Sain
Thomas_Rohde
Sisko
Posted: ‎2025-07-29 12:48 AM
Hello Dinesh!
Can you please be more specific with your request number one?
Sorry, but I do not understand it clearly. Perfect would be a diagram or a table to identify clearly what should happen and when.
Related to point 2
Here the script:
-- Description: Analyses a temperature and depending on a certain temperature range a defined
-- Setpoint Temperature needs to be send out
-- Skript needs to be placed within \Scripting\Event-based.
-- The skript needs to be linked with the GA of the dedicated measured temperature.
-- The script will check the measured temperature and within a certain temperature range a
-- defined setpoint temperature will be sent out.
-- NEEDS TO BE ADAPTED! --------------------------------------------------------------------------
GA_SetPointTemperature = '43/1/2' -- GA needs to be adapted
SetPointTemperature = 24
TemperatureRangeHigh = 27
TemperatureRangeLow = 25
-- DONT CHANGE CODE BELOW ------------------------------------------------------------------------
CurrentTemperature = event.getvalue() -- Get actual temperature
if (CurrentTemperature > TemperatureRangeLow and CurrentTemperature < TemperatureRangeHigh) then
grp.checkwrite(GA_SetPointTemperature, SetPointTemperature)
end
Kind regards
Thomas
