U-Motion Client Stuck in Syncing Web Services
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • U-Motion Client Stuck in Syncing Web Services
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Posted: ‎2020-07-05 03:45 AM . Last Modified: ‎2024-07-14 11:48 PM
10617
Hi All
After finishing configuration in U motion Client 10" (setting Ip and wiser link to expose the Virtualization), it Stuck while opening in that screen attached.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2020-07-15 11:18 PM
Hi Adham,
it seems that the CTP is running again. If everything is working as expected than please mark it as "Accept as solution".
This helps to identify open topics vs solved ones.
Many THANKS for your help in advance!
Kind regards
Thomas
Application Design Engineer
Replies 43
Thomas_Rohde
Sisko
Posted: ‎2020-07-05 11:48 PM
10615
can you please be a bit more precise with the exact mistake.
  - Do you mean that the TP shows the visu but cant be controlled?
  - Or does it show another screen and get stuck with it?
Beside that can you please deliver more software details (FW-Versions of CTP and Wiser4KNX).
Is it possible that you share a picture?
Kind regards
Thomas
Posted: ‎2020-07-08 04:08 AM
10611
Hi Thomas
The issue that the U.motion cannot load the web services to be able to show SE GUI
Here  more details about the product :
MTN6260-310
U.Motion Client Touch 10
regarding FW ver for the client screen i cant get it as i cant access the web page of the page as it shows me the message attached below
Wiser FW ver 2.5
So is there a way to reset it or re-install OS for the screen ?
Best regards
Adham
Thomas_Rohde
Sisko
Posted: ‎2020-07-08 04:24 AM
10608
Hi Adham,
are you sure that you have:
- entered the correct url to your W4K-Page => Does this URL works within a browser on your computer
- are you sure that your settings has been stored correctly?! Otherwise the CTP maybe still looks for U.Motion-Server.
- Do you know that the CTP has a webserver? Means that you can check your settings from the PC even when
  the CTP stays in this screen?
=> So I recomment that you try to use the webserver in order to double check your settings. Means you simply enter in a browser
on your computer the IP of the CTP (ClientTouchPanel) to reach the settings of the device.
Kind regards
Thomas
Posted: ‎2020-07-08 04:38 AM
10606
Hi Thomas
- Url was entered correctly and it was working and viewing visualization correctly
- All data was saved correctly
- find attached the message i got when i access it via IP
So, is there another way to access CTP other than though IP as shown in attache file ?
Best regards
Adham
Thomas_Rohde
Sisko
Posted: ‎2020-07-08 05:33 AM
10601
Hi Adham,
this means the CTP was working for a while and suddenly not anymore?!
For how long it was working?
Kind regards
Thomas
Posted: ‎2020-07-08 05:57 AM
10599
Hi Thomas
Yes, it was working
i have done the  main configurations ( setting IP, setting Wiser URl ... ), and it worked well at first
after trying to start it again in site it showed that Error message.
Best regards
Adham
Thomas_Rohde
Sisko
Posted: ‎2020-07-08 06:02 AM
10597
Hi Adham,
ok, did you face the same issue when you built just a small system (Router, W4K, CTP, PC)?
Just to make sure that there is no network issue. Did you tried this?
Kind regards
Thomas
Posted: ‎2020-07-08 06:28 AM
10595
Hi Thomas
I am doing so right now
Router , CTP , PC only and trying to access  CPT but i only get this message.
no network issues latest IP configuration are still saved on CPT
the issue that when CPT tries to access localhost where SE application should be loaded via chrome it stuck as shown
this the link which CPT trying to access
http://192.168.1.203/smartdomuspad/modules/system/nowebservice.html  through PC
http://127.0.0.1/smartdomuspad/modules/system/nowebservice.html   Through Chrome in CPT
Br
Adham
Thomas_Rohde
Sisko
Posted: ‎2020-07-08 06:50 AM
10592
Hi Adham,
you get this URL(http://192.168.1.203/smartdomuspad/modules/system/nowebservice.html) when enter just the IP (192.168.1.203) of the CTP within your browser on the PC?
Kind regards
Thomas
Posted: ‎2020-07-08 06:54 AM
10590
Hi Thomas
yes and syncing web services message appears and it tries to refresh each 5 secs with same result
Br
Adham
Thomas_Rohde
Sisko
Posted: ‎2020-07-08 06:59 AM
10587
Hi Adham,
this means that you have no access from the PC to the CTP. How can you be sure that your settings are still correct?
Did you stopt during the bootprocess of the CTP at some point?
Can you share the URL which you have entered to reach the W4K?
Kind regards
Thomas
Posted: ‎2020-07-08 07:05 AM
10583
Hi Thomas
I am sure that all setting are saved bec it have the same static IP and i changed the screen saver picture and it appears as i set first time.
the URL of wiser for visualization : http://admin:Admin123@192.168.1.202/cgi-bin/scada-vis
" Did you stopt during the bootprocess of the CTP at some point? " what did you mean with this ?
wiser IP : 192.168.1.202
Br
Adham
Thomas_Rohde
Sisko
Posted: ‎2020-07-08 07:08 AM
10581
Hi Adham,
you can connect a keyboard to the CTP and when you restart the CTP there comes somewhere a SE-Green page where you can press a key and you get to the settings on the CTP himself.
Maybe it will help to identfy your settings.
Kind regards
Thomas
Posted: ‎2020-07-08 07:40 AM
10578
Hi Thomas
The problem is that CTP doesn't reach this step.
When it is turned on i get a blue desktop for a while and then the sync message appear.
Br
Adham
Erwin-vd-Zwart
Janeway
Posted: ‎2020-07-08 07:48 AM
10575
I would try a couple of things, first of all i asume you have recent FW on your Wiser so you should change your url to http://ip/scada-vis without the /cgi-bin/ as this will force a redirect on th CTP and not sure how it handles that, next to that i would try to disable password in the user settings of the Wiser and try a url without the admin:Admin123@ as basic authentication is not supported in modern browsers anymore, Not sure if latest CTP FW blocks it now (not tested it yet), so test it to be sure that is not the case..
BR,
Erwin
Posted: ‎2020-07-08 08:03 AM
10572
Hi Erwin
it seems that you dont get my problem correctly.
The issue is in the CTP not wiser !
Wiser is working correctly and i have no issue with it.
CTP should open a web page (application or web service) which is the green screen to start loading visualization or skip it  to enter credentials to enter admin page of CTP.
the issue here is that green screen cannot load and i get the error uploaded in the thread. so its an issue with the CTP itself not wiser.
Br
Adham zaki
Posted: ‎2020-07-08 08:13 AM
10568
Hello
attached a vid for the sequence of CTP
Br
Heribert_Dölger
Commander
Posted: ‎2020-07-08 08:26 AM
10561
The pic shown in the vid: is this the screensaver pic or part of the visu of W4K?
If scrreensaver: what is the memory size of the pic?
Thomas_Rohde
Sisko
Posted: ‎2020-07-08 11:38 PM
10552
Hi Adham,
thank you for creating the video because it helps a lot to better understand issue.
Means that we do not need to talk about the settings in a first step.
The video shows NOT a normal startup/bootprocess.
Is it a complete new device from stock?
Did you made any system software changes/adaptations?
Because the bluescreens and as well the other screen (like a screensaver) looks really strange.
Did you uploaded a screensaver pic? If yes, was it that what was sometimes appearing?
Kind regards
Thomas
Posted: ‎2020-07-09 12:34 AM
Hi Heriber
its just a screen saver that i set before when CTP was working 1st time
its size about 300 KB
Br
Adham
Posted: ‎2020-07-09 12:39 AM
10547
Hi Thomas
No this is the normal startup but this blue screen normally appears for half a sec before loading SE GUI
( i tried another working CTP and  this screen appears for half a sec before starting SE GUI )
i Just modified the Screen saver (this action i did in several CTPs before smoothly without any errors)
As i mentioned before All setting i applied before is working well (static IP, screensaver), only SE GUI cant boot and i get that message.
I think i need to get the stock software or OS to re install in this CTP. So, is there any guide to do so ?
Br
Adham
Heribert_Dölger
Commander
Posted: ‎2020-07-09 02:14 AM
10542
Hello Adham
I guess you are right to get initial OS installed from scratch or at least check the file system.
File system is created individually for each U.motion product separately. So I would need the serial number of the tocuch panel (you find it on the backside of the CTP).
In case you have other panels showing same problem I would need their serial numbers as well.
I will need the help of a developer for that. Most probably it will be necessary to establish a remote session (for example with teamviewer) to the CTP. Could that be made possible?
I will not be in the office by tomorrow. So hopefully we can arrange everything needed by today.
BR, Heribert
Posted: ‎2020-07-09 05:10 AM
10538
Hi  Heribert
Unfortunately, Today i am out of the office.
can we re-schedule that Next week starting from Monday?
Thanks in advance
Adham
Heribert_Dölger
Commander
Posted: ‎2020-07-09 05:27 AM
10534
Hi Adham
No problem. Let's continue on Monday.
Wish you good weekend!
BR, Heribert
Posted: ‎2020-07-13 04:29 AM
10526
Hi  Heribert
Hope everything going well
Can we proceed today with resetting the CTP ?
Find attached images including CTP serial number.
Best Regards
Heribert_Dölger
Commander
Posted: ‎2020-07-13 08:36 AM
10522
Hello Adham
sorry for late reply, was too busy during whole day.
I have just reported your issue to our developers. Not sure if they will reply within today as it is already quite late. Will let you know as soon as I get response from them.
And many thanks for providing additional info like serial number.
Best regards
Heribert
Heribert_Dölger
Commander
Posted: ‎2020-07-14 02:40 AM
10511
Hello Adham
So far no feedback from developer except that they will take care on the issue.
BR, Heribert
Heribert_Dölger
Commander
Posted: ‎2020-07-14 08:07 AM
10510
Hello Adham
Can you provide team viewer access data?
Developer then will contect to the panel.
Best regards
Heribert
Posted: ‎2020-07-14 08:14 AM
10508
Hi @Heribert_Dölger
kindly find attached team viewer credentials .
Hint: screen is not accessible now ! as it is not booting up and stuck in booting the kernel
Br
Heribert_Dölger
Commander
Posted: ‎2020-07-14 08:33 AM
10503
Just informed developer about status of screen. Will let him decide about further steps.
Heribert_Dölger
Commander
Posted: ‎2020-07-15 12:16 AM
10496
Hello Adham
Developer just answered:
The given credentials give "no connection possible".
Please try to reboot and run teamviewer again.
Can you please let me know after team viewer is up again?
Many thanks!
Heribert
Posted: ‎2020-07-15 12:21 AM
10493
Hi Heribert
unfortunately, I am not in the office right now . I ll be there after approx 4 hrs .. at 1 pm Cairo time.
can we proceed at that time ?
best regards
Heribert_Dölger
Commander
Posted: ‎2020-07-15 12:24 AM
10491
Hello Adham
Thanks for feedback. I will inform the developer that you will be available in the afternoon.
Please let me know once we can continue.
Heribert
Posted: ‎2020-07-15 03:45 AM
10487
Hi Heribert,
I am in office now and find TeamViewer credentials attached.
Thanks in advance
Heribert_Dölger
Commander
Posted: ‎2020-07-15 03:55 AM
10484
Hello Adham
Thanks for sharing. Most probably developer will not be able to connect as the panel is in such state. But I am waiting for his confirmation.
Will let you know.
Best regards
Heribert
Heribert_Dölger
Commander
Posted: ‎2020-07-15 04:37 AM
10480
Hello Adham
Developer just informed me that he was able to restore functionality.
Can you confirm the panel is working again?
Many thanks.
Heribert
Posted: ‎2020-07-15 04:39 AM
10477
Hi Heribert
Yes, it working now (Y)
Thanks for your cooperation and help.
It seems just a software issue.
Is the any precautions should I follow to prevent that from happening again ?
Best regards
Heribert_Dölger
Commander
Posted: ‎2020-07-15 04:42 AM
10475
I am happy to hear that.
What you might do as precaution is to clear the cahce memory of the panel. You can find this option in settings menue of the panel. I'd recommend to do this after configuration.
Best regards
Heribert
Posted: ‎2020-07-15 04:51 AM
10473
Hello Heribert
Thanks for advise
Have a great day (Y)
Thomas_Rohde
Sisko
Hi Adham,
Kind regards
Thomas
Posted: ‎2021-02-11 01:06 AM
10454
Regarding to the above mention problem, I'm facing the same problem in another screen with serial number : S2002656
TeamViewer ID : 645 443 625
Whenever you can join, Please tell me.
Thanks in advance
@Heribert_Dölger
Heribert_Dölger
Commander
Posted: ‎2021-02-11 01:18 AM
10452
Hello Adham
Will try to get developer to have a look onto your panel. What panel is it, 10'' or 15'', client or server?
And what is the passcode for the team viewer access?
Best regards
Heribert
Posted: ‎2021-02-11 01:20 AM . Last Modified: ‎2021-02-11 01:25 AM
Thanks for fast reply.
It's client 10"
Passcode : f576hs
Panel IP : 192.168.1.130
username : admin
password: admin
