Touch 3 widgets, no plus sign to create
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Touch 3 widgets, no plus sign to create
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Si67
Si67
Cadet
Posted: ‎2024-09-17 04:05 AM . Last Modified: ‎2024-09-17 04:10 AM
513
I have a homeLYnk HW v1.3
I have updated the FW to V3 (old)
When I try to create a widget in touch config there is no means to add one, the manual says press the plus symbol to create one but the plus symbol is missing only the gear and X symbol are presant.
I deleted the touch 3 app and reinstalled it though the problem remains.
Equally when I switch to the Touch tab there is no tab to add widget.
So it seems that currently I can neither create nor add a widget????
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2024-09-18 01:30 AM
Hello Si67!
Means you miss the button marked in green?
Maybe it is a cache issue within the browser. Please try to use the incognito mode of your browser and double check if the problem still exist.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Hello Si67!
Kind regards
Thomas
