Support Required : Integration with KNX devices ,iEM3250 with HomeLYnk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Support Required : Integration with KNX devices ,iEM3250 with HomeLYnk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa210173
sesa210173 Schneider Alumni (Retired)
Posted: ‎2014-07-29 12:42 AM . Last Modified: ‎2024-07-15 12:06 AM
904
Can any one help me out in configuring KNX ,iEM 3250 meter with HomeLYnk
It will be great if you can share sample program files
Regards
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Replies 4
Posted: ‎2014-07-29 12:53 AM
You should check this:
Good luck
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2014-07-29 01:09 AM
-- pm3250
-- sample reading Classic methode
if not mb3 then
require('luamodbus')
mb3 = luamodbus.rtu()
-- Config. parameters in PM
mb3:open('/dev/RS485', 19200, 'E', 8, 1, 'H')
mb3:connect()
end
-- slave number configured in PM
mb3:setslave(3)
mb3:flush()
local frecuencia, tension
frecuencia = mb3:readregisters(2016) -- register 2017 frecuency
grp.write('7/7/7',frecuencia) --Going to KNX
r1, r2 = mb3:readregisters(3027, 2)-- register 3028 Voltage L1-N
if r1 then
tension = bit.lshift(r1, 16) + r2
tension = lmcore.inttohex(tension , 4)
tension = knxdatatype.decode(tension , dt.float32)
grp.write('7/7/8', tension ) --Converted value to KNX
else
  --- on error
  log("Comunication error slave[03] PM3250 ")
  log(r1)
end
There is also a guide on kioske done with an internal library..
AN003 Modbus Power meters and homeLYnk .zip
sesa210173
Posted: ‎2014-07-30 02:27 AM
815
Thanks for the support Mr.Pawel and Mr esteve, I made a successful communication in between KNX devices ,iEM device and HomeLYnk.
Is it possible to create profiles for each user? i.e
Floor 1 can be control by User 1
Floor 2 can be control by User 2
User 1 should not see and control the content of Floor 2 and vice versa
Regards
sesa189443
sesa189443 Schneider Alumni (Retired)
Posted: ‎2014-08-01 03:29 AM
Unfortunately user management is very poor in HL we have only 3 users but all of them are assigned to the same visualisation only with different rights. In 1.3 we will have proper management and you will be able to do it
There is a trick how to make separate visu for a user but the difference is the URL, User and password stays the same for both If you interested let me know.
