Share Your Feedback โ€“ Help Us Improve Search on Community!
Spacelynk, change clock with script
SpaceLogic KNX Forum
Showing results forย
Did you mean:ย
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Spacelynk, change clock with script
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dรถlger
Commander Heribert_Dรถlger Commander
31
Back to SpaceLogic KNX Forum
P_Bergman
P_Bergman
Cadet
Posted: โ€Ž2025-10-09 03:52 AM
487
If the spacelynk aren't connected to a network/NTP.
Is there a way to change the clock, due to daylight saving time?
Through a scheduled script perhaps?
Anyone with a code?
Or is there something "built in" for this that i have missed?
Regards
  • SpaceLYnk
ratorg
Ensign ratorg
Ensign
Posted: โ€Ž2025-10-09 04:04 AM
481
โ€ƒSet you time zone in Configurator -> Utilities -> Date and time
Erwin-vd-Zwart
Janeway
Posted: โ€Ž2025-11-03 09:20 PM
@P_Bergman
Yes, the controller will run his clock according the regional settings you have set including DST,
However when you send a new time/date via script the controller takes that over without calculation for itโ€™s current regional settings so the time you send must be the current time for the region you are in.
When having a DCF77 or KNX time sender to set the date and time via script you must set the correct region and DST there as well.
My advice is to connect the controller where possible to the great IoT world (itโ€™s made for that ๐Ÿ˜‰) to benefit of NTP and more..
Replies 5
ratorg
Ensign ratorg
Ensign
482
Erwin-vd-Zwart
Janeway
Posted: โ€Ž2025-10-09 11:42 PM . Last Modified: โ€Ž2025-10-09 11:47 PM
1
465
@P_Bergman @ratorg
This can be done from script:
--FROM KNX TO CONTROLLER
date = grp.getvalue('1/1/1')
time = grp.getvalue('1/1/2')
cmd = string.format("date -s '%d-%d-%d %d:%d:%d'", date.year, date.month, date.day, time.hour, time.minute, time.second)
os.execute(cmd)
It might be needed to disable this setting:
Add a DCF77 receiver / time giver to your KNX objects and you don't need NTP, but as with any modern IoT product i don't understand why it's not able (or better said allowed) to connect to WAN to get the NTP...
Thomas_Rohde
Sisko
Posted: โ€Ž2025-10-28 06:25 AM
Hello P_Bergman!
Is this topic solved?! Please let us know ๐Ÿ˜‰
Kind regards
Thomas
Application Design Engineer
P_Bergman
P_Bergman
Cadet
Posted: โ€Ž2025-11-03 11:51 AM
245
๐Ÿ‘ ok, great, so if you choose an area/city that uses daylight saving time (or not), then clock will change accordingly?
Erwin-vd-Zwart
Janeway
@P_Bergman
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
