SpaceLynk Lua for 2 Step Dimming
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLynk Lua for 2 Step Dimming
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Posted: ‎2016-05-08 09:00 PM . Last Modified: ‎2024-07-14 11:55 PM
4
868
Hi Guys,
I'm trying to include below flow diagram to SpaceLynk , but i have limited knowledge in Lua.
The function will be like this
While sensor trigger light on ->After 300sec if no movement dim down to 50% ,If got movement restart timer ->After another 300Sec no movement turn off light, if there is movement the light back to 100%.
Appreciate someone coach me for this.
Attach will be the flow diagram and here is the code
while 1
    if (value==true) then
        Timer1=300
        Timer2=300
        grp.write('1/1/1',255)
    else
        while value == false do
            if Timer1 > 0 then
                Timer1 = Timer1 - 1
            elseif Timer1 == 0 then
                grp.write('1/1/1',125)
                if Timer2 > 0 then
                    Timer2 = Timer2 -1
                elseif Timer2 == 0 then
                    grp.write('1/1/1',0)
                end
            end
            value = event.getvalue()
        end
    end
end
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Replies 4
Thomas_Rohde
Sisko
Posted: ‎2016-05-11 10:56 PM
772
Hi Lee,
by random I found a script on the HL of Erwin van der Zwaart. I guess it will meet your requirements.
-- ** Staircase logic with external time object and retriggering on input object Version 3.1 ** --
-- ****************************** Created by Erwin van der Zwart **************************** --
-- ************************************** SET PARAMETERS ************************************ --
-- Set input address
AddressInput = '6/0/0'
-- Set output address
AddressOutput = '6/0/1'
-- Set external time address (optional)
AddressExternalTime = '6/0/2'
-- Use time left indication
UseTimeLeft = true -- Set to false if no time left indication is used
-- Set feedback adress of time left indication (optional)
AddressTimeLeft = '6/0/3'
-- Set time delay (Used when external time is not available)
SetDelay = 10
-- Seconds or Minutes
SetSec = true -- Set to false for Minutes
-- Set factor delay (Multiplies Delay)
SetFac = 1
-- Set unique name for staircase timer (to avoid same storage name usage)
StaircaseName = 'Staircase_1'
-- Logic can be turned of by value 0
Off_by_Value_Zero = false
-- ************************************** END PARAMETERS ************************************ --
-- *************************** DON'T CHANGE ANYTHING UNDER THIS LINE ************************ --
inputvalue = event.getvalue
if Off_by_Value_Zero == false and (event.getvalue() == false or event.getvalue() == 0) then
  -- Exit script
  return
end
ValueInput = grp.getvalue(AddressInput)
ValueOutput = grp.getvalue(AddressOutput)
ValueExternalTime = grp.getvalue(AddressExternalTime)
if SetSec == true then
  SetSeconds = 1
else
  SetSeconds = 60
end
if ValueExternalTime == nil then
ValueExternalTime = 0
end
if ValueExternalTime > 0 then
  StairCaseTime = ValueExternalTime * SetSeconds * SetFac
else
  StairCaseTime = SetDelay * SetSeconds * SetFac
end
if ValueInput == true then
  --check for earlier started scrips
  --check storage for stpid value
  stpid = storage.get(StaircaseName)
  --check if stpid has a value
  if stpid == nil then
          pid = os.getpid()
          storage.set(StaircaseName, pid)
  else
          -- kill earlier running script
          os.kill(stpid, signal.SIGKILL)
        -- create new pid for next time to kill
          pid = os.getpid()
    end
  if ValueOutput == false then
    grp.write(AddressOutput, true)
    ValueOutput = true
  end
  -- Check time left indication is used
  if UseTimeLeft == true then
    if StairCaseTime > 0 then
        grp.update(AddressTimeLeft, StairCaseTime)
        repeat
          StairCaseTime = StairCaseTime - 1
          os.sleep(1)
        until StairCaseTime == 0
    end
  else
    os.sleep(StairCaseTime)
  end
  if ValueOutput == true then
        grp.write(AddressInput, false)
      ValueInput = false
    end
    if Off_by_Value_Zero == false then
            grp.write(AddressOutput, false)
        ValueOutput = false
          end
    else
      -- Do nothing, this will trigger else condition below on next run
    end
  end
else
  else
    grp.update(AddressTimeLeft, 0)
    pid = nil
    end
  end
end
Kind regards
Thomas
Application Design Engineer
Posted: ‎2016-05-11 11:05 PM
772
Hi Thomas,
Many thanks I will test it whole back to home . Now meeting with customer
Sent from my iPhone
Thomas_Rohde
Sisko
Posted: ‎2016-08-05 12:20 AM
772
Hello Lee,
in case this topic is answered please mark it accordingly so that we can get a better view on which kind of topics are really still open.
Thanks a lot for your understanding and support.
Kind regards
Thomas
Kind regards
Thomas
Posted: ‎2016-08-11 12:32 AM
Hi Thomas,
I will update the latest one by tomorrow.
