SpaceLynk LSS100200 modbus visualization
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLynk LSS100200 modbus visualization
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Andreabolis98
Andreabolis98
Cadet
Posted: ‎2024-08-08 09:20 PM
913
Hi everyone,
I am new on Spacelynk platform, for a new application with SpacLynk LSS 100200 i need to:
- read and write a list of holding register from 4 modbus server device (with different id);
- i dont have a KNX network connected to the SpaceLynk.
- visualization via webserver the data come from Modbus
- create scenario and scheduler.
My questions are:
- can i comunicate with 4 modbus server devices simultaneously?
- in webserver Widgets, can i read and write directly the modbus variables or i have to convert before in knx group?
- for schedule, scenario and visualization, is it a problem if i dont have a real knx network connected to the spaceLink? or its enough to create a vistual object on knx ?
- is there an offline configurator? At the moment i dont have spaceLynk phisically.
Thanks.
Best regards
  • SpaceLogic devices
  • SpaceLYnk
alexcarey
Crewman alexcarey
Crewman
Posted: ‎2024-08-09 03:26 AM . Last Modified: ‎2024-10-02 10:24 PM
@Andreabolis98 wrote:
Hi everyone,
My questions are:
Thanks.
Best regards
  1. Modbus Communication: Yes, you can communicate with multiple Modbus server devices simultaneously with SpacLynk LSS 100200.
  2. Webserver Widgets: Widgets on the webserver can read and write Modbus variables directly without needing to convert them to KNX groups.
  3. KNX Network: You can still create schedules, scenarios, and visualizations without a physical KNX network. Virtual KNX objects should be sufficient.
  4. Offline Configurator: SpacLynk typically does not offer an offline configurator. You might need to wait until you have physical access to the SpacLynk device for full configuration.
fire kirin
nulls brawl download apk
alexcarey
Crewman alexcarey
Crewman
Hi everyone,
My questions are:
Thanks.
Best regards
fire kirin
