SpaceLogic LSS100300 gateway
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLogic LSS100300 gateway
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
ElvisOla
Crewman ElvisOla
Crewman
Posted: ‎2025-10-10 03:18 AM
9
700
Hello team.
I added the KNX spacelogic BMS IP Gateway module (LSS100300) to the Bacnet interface in the EBO 2024 software version 6.0.3.112 under the AS-B-24-P control unit. How can I display the CIAT air conditioners that are connected in KNX serial mode on the LSS100300? I cannot find the KNX section in the EBO software settings or in the LSS100300 properties. Do I need to load a KNX driver to detect or manually add the air conditioners? If so, please guide me on how to do this.
Translated with DeepL.com (free version)
  • Other
  • SpaceLogic devices
Replies 9
Thomas_Rohde
Sisko
Posted: ‎2025-10-28 06:23 AM
608
Hello ElvisOla!
To "How can I display the CIAT air conditioners that are connected in KNX serial mode on the LSS100300?"
You need to import into the LSS100300 either the dedicated ETS-Project or only the Group-Address-Export.
With both ways you implement simply the dedicated GA and you can decide which GA's you really need for the exchange between KNX+BACnet.
Of course you need to adapt within LSS100300 the dedicated BACnet-Server details.
Sounds like a plan?!
Kind regards
Thomas
Application Design Engineer
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2025-10-28 11:26 PM
7
598
Hallo@ElvisOla
here are some steps you have to follow
1- import your ETS project into the BMS IP GATEWAY. Now you should see all the planned group addresses within the KNX object section
2- select which of those KNX objects should be exported to the BACNet interface. Simply click on the dedicated “export” checkbox.
3- Navigate into the System/Interface/BACnet menu and set all the necessary fields like BACnet ID, BACnet Name etc.
4- Open your Building Operation workstation, select you AS and use the Device Discovery function to detect your BMS GATEWAY.
5- Drag the BMS GATEWAY within your AS BACnet IP network.
6- right click on the BMS GATEWAY within the BACnet interface, then select the device/upload all objects menu. All the selected KNX objects should be now listed as BACnet objects
ElvisOla
Crewman ElvisOla
Crewman
Posted: ‎2025-11-05 02:25 AM
529
Hello Cristiano
I am attaching a video and a screenshot of what happens when I try to import the knxpro file sent to me by the manufacturer of CIAT air conditioners.
The import was done from the gateway's web interface and it is not working.
I have already added the LSS100300 under AS in EBOW.
Thank you for your help.
Please help.
Thomas_Rohde
Sisko
Posted: ‎2025-11-06 12:20 AM
521
Hello ElvisOla!
Is the ETS-Project protected with a password?
Would you mind to share the ETS-Project?
Kind regards
Thomas
ElvisOla
Crewman ElvisOla
Crewman
Posted: ‎2025-11-10 12:34 AM
464
Hello Thomas Rhode
No, the knxpro files do not have a password and were sent to me by the manufacturer of CIAT air conditioners. Attached is the compressed file sent by the manufacturer, which I have unzipped. I tried several, but none of them worked. Or is the ETS file you are referring to different from the KNXPRO file?
Fiches param knxproj.zip
Thomas_Rohde
Sisko
Posted: ‎2025-11-10 07:49 AM
3
449
Hello ElvisOla!
I have checked the first project out of the many ones you sent.
By doing so, I saw that this ETS-Project consists only out of one device.
And I guess the parameter settings are still unchanged (Default).
However … the blocking point here is, that there is no group-address linked to any of the objects.
There is not even created a single KNX Group Address.
The KNX-Group-Addresses are the essential details which the KNX BMS IP Gateway takes out of the ETS-Project!
If no Group-Address is part of your project, it does not make sense to import, it which leads to the error message.
I guess the best way of support would be to go in local contact with a SE KNX Specialist.
In which country are you located?
Kind regards
Thomas
ElvisOla
Crewman ElvisOla
Crewman
Posted: ‎2025-11-11 06:11 AM
408
Hello Thomas Rohde,
Thank you for your reply.
I would like you to help me get in touch with a KNX SE specialist who can help me finalize the KNXPRO file. I am in Benin (West Africa).
If possible, I would appreciate your help or guidance on how to create the KNX GROUP ADDRESS to import the file and resolve the issue.
All air conditioners are CIAT brand and have a KNX port connected in bus mode to the LSS100300 control unit.
Thank you very much for your response.
Quintus23
Quintus23
Cadet
Posted: ‎2025-11-18 12:38 AM
Hey,
Are your CIAT controllers V3000 models? If so, not all KNX variables can be converted to BACNET, for example the 3 x 2 bytes.
Good luck !
ElvisOla
Crewman ElvisOla
Crewman
Posted: ‎2025-11-18 01:24 AM
Hello Thomas Rohde,
I replied to you last Monday, but I don't know if you saw my message.I would like you to help me get in touch with a KNX SE specialist who can help me finalize the KNXPRO file. I am in Benin (West Africa).
