If you are trying to connect Wiser to SmartThings please write below this post. I am now connected to the refrigerator. API is pretty stable.
https = require('ssl.https')
json = require('json')
ltn12 = require('ltn12')
token = 'YOUR PERSONAL TOKEN'
tbl = {}
res, code = https.request({
url = 'https://api.smartthings.com/v1/devices/YOUR DEVICE ID/status',
method = 'GET',
headers = {
['authorization'] = 'Bearer ' .. token,
['content-type'] = 'application/json',
sink = ltn12.sink.table(tbl),
if res and code == 200 then
resp = table.concat(tbl)
resp = json.pdecode(resp)
-- Found a value in table with setpoint here:
local FridgeTemp = resp["components"].cooler.temperatureMeasurement.temperature.value
local FreezerTemp = resp["components"].freezer.temperatureMeasurement.temperature.value
local FridgeDoor = resp["components"].cooler.contactSensor.contact.value
local FreezerDoor = resp["components"].freezer.contactSensor.contact.value
grp.checkupdate('33/1/11', FridgeTemp )
grp.checkupdate('33/1/12', FreezerTemp )
grp.checkupdate('33/1/16', FridgeDoor )
grp.checkupdate('33/1/17', FreezerDoor)
Hello Ozturker,
many THANKS for sharing the script with the community!
Really appreciated! 🙂
Hello Ozturker,
I was thinking on your post ... we will make it more comfortable for you 😉
Just working on the certification.IFA-Fair Berlin, Sep. 2024
