Push button installation
SpaceLogic KNX Forum
Select a Country
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Push button installation
Thomas_Rohde
Thomas_Rohde Champion
142
Erwin-vd-Zwart
Erwin-vd-Zwart Champion
65
Heribert_Dölger
Heribert_Dölger Leader
37
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Aribay
Aribay Explorer
Explorer
Posted: ‎2023-11-30 10:28 PM . Last Modified: ‎2024-07-14 11:41 PM
1276
Hello everyone,
Do SE KNX push buttons come with mounting frames and face plates? such as MTN627660 (Push-button, 2-gang plus, aluminium, System M).
I don't see any of it from the catalog.
Are these types of things ordered from a different vendor?
Thanks.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Documents
Thomas_Rohde
Champion
Posted: ‎2023-12-05 02:45 AM
Hello Aribay,
the product you mentioned will come with a so called fixing frame (mounting frame).
This fixing frame is needed to install the product on a dedicated installation box (brick/hollow wall).
To complete the product you need to order seperately a dedicated design frame.
The installation process is the following:
- You install first the fixing frame on the installation box.
- Then you take the design frame and put the pushbutton inside.
- Connect the KNX connector with the combination of pushbutton and designframe.
- Click the pushbutton+designframe into the fixing frame. => Done
To "I don't see any of it from the catalog."
In which catalogue you are looking? Into the KNX one (Where are only KNX products included)?
If so you need to look into the complete catalogue of your local country organization.
An example of a dedicated design frame could be:
https://www.se.com/fr/fr/product/MTN4010-3660/mpure-cadre-simple-alumi-nium/
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Champion
Hello Aribay,
Kind regards
Thomas
