Problem with Wiser for home (HomeLynk) with hex cod in RS232
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Problem with Wiser for home (HomeLynk) with hex cod in RS232
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa440970_brid
sesa440970_brid Schneider Alumni (Retired)
Posted: ‎2018-02-25 12:39 AM . Last Modified: ‎2024-07-14 11:50 PM
3639
Dear all,
In a project with Wiser for KNX (Home Lynk) and we want an integrate between Caseti fan coil (RS232 port) and WFK (RS232), All settings are done according to the guide, The commands are sent as a Hex code to turn on the fan coil to the port, But fan coil has no reaction. The codes sent by WFK are displayed as ASCII code when read by Hercules software. Hex codes are displayed in Hex when they are in the range of 0x00 to 0x1f in the format {}. Hex codes are displayed in Hercules, when they are in the range of 0x00 to 0x1f in this format {} and codes above 0x1f as an ASCII code, This means that they are displayed without {}.
The code for the fan coil is above 0x1f, So there is no reaction. But to turn off the fan coil, because the code is 0x00, it's easy to turn off the command and run. Also, information sent from the side of the fan coil is Hex code which is read by WFK. But the codes read in WFK and in the Alert part are displayed as ASCII characters and there is no way of detecting the information.
Find the attached files.
Best Regards
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (5)
  • fan coil
  • homelynk
  • lss100100
  • rs232
  • wiser for knx
Replies 6
Posted: ‎2018-02-26 04:28 AM
1
3560
Hi, instead of your port:write use:
data = string.char(0x01, 0x10, 0x00, 0x01, ................ )
port:flush()
port:write(data)
sesa440970_brid
Posted: ‎2018-02-28 05:17 AM . Last Modified: ‎2025-07-09 04:18 AM
Hi Pawel,
As you can find in the attached files, I try to use both commands, once we use port: write and then we use the second command string.char but the result was same.
When the Hex code is greater than 0x1f, it is represented as an ASCII (We see this in the Hercules software). Pawel Michalowski ​
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2018-03-05 03:06 AM
3
3560
Hello Danial,
Can I ask why are you using RS232 instead of Modbus communication?
In documents you attach they are refer to Modbus communication and Modbus registres.
Thank you for clarification
David
sesa440970_brid
Posted: ‎2018-03-08 12:13 AM . Last Modified: ‎2025-07-09 04:19 AM
3560
Hello David,
Please kindly see in CASSETTE FCU mod-bus manual.pdf attached. On page 5 says: "The Protocol is similar to "Modbus Application Protocol V1.1B", not equal to Modbus."
Best Regards
David Navratil​
David_Navratil
Lt. Commander
Posted: ‎2018-03-12 12:32 AM
3560
Hello Danial,
So far I do not find any mistakes in your code. I am in testing, please be patient.
I will update you asap.
BR
David
sesa440970_brid
Posted: ‎2018-03-12 03:43 AM
Thank you David.
