Presence Simulation for HomeLYnk / SpaceLYnk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Presence Simulation for HomeLYnk / SpaceLYnk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa149896_brid
sesa149896_brid Schneider Alumni (Retired)
Posted: ‎2017-04-20 03:31 AM . Last Modified: ‎2024-07-14 11:53 PM
2
1081
Dear all,
is anyone of you aware of a HL or SL solution, which allows a presence
simulation without using a Schedulers?
A command should make the HL s start recording the group addresses for 2 weeks.
The recording should be played for 2 weeks, again triggered by a command.
Many Thanks
Benjamin
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (2)
  • homelynk
  • spacelynk
sesa264057_brid
sesa264057_brid Schneider Alumni (Retired)
Posted: ‎2017-08-15 05:11 AM
1
1014
Hi Benjamin.
Here is the script for presence simulation. But it only records 1 day or 1 week or record always.
Br
Martin Rausch
----Create EVENT-BASED SCRIPT---------------------
-- Presence Simulation Module Version 2.0 - Recording part
-- Created by Erwin van der Zwart
-- ********** SET PARAMETERS ***********
-- Set address for selecting modus of Simulation Module (0 = Recorder off, 1 = Record Today, 2 = Record Sunday, 3 = Record Monday, 4 = Record Tuesday, 5 = Record Wednesday, 6 = Record Thursday, 7 = Record Friday , 8 = Record Saturday, 9 = Record Midweek, 10 = Record Weekend, 11 = Record Full Week from Activation, 12 = Record Full Week from Day 1, 13 = Record Always, 14 = Record to Play Direct, 15 = Player Active, 16 = Delete all recorded data)
Address_Modus = '1/1/125'  -- Byte object ! -- Set as byte address with custom text and min/max 0 to 14 and make a separate button for value 15 with pincode (delete all recordings)
-- Set address for play and stop
Address_Play_Stop = '1/1/126' -- Bit object !
-- Set address for delete recordings
Address_Delete = '1/1/127' -- Bit object !
-- Set Conformation LED play / stop (Optional)
Address_Play_Stop_Feedback = '1/1/128' -- Bit object !
-- Set Conformation LED delete (Optional)
Address_Delete_Feedback = '1/1/129' -- Bit object !
-- Set TAG used for selecting objects to be record
Recording_Tag = 'Simulatie'
-- Set scriptname for playing recorded objects and to disable/exit this recording (to avoid loop recording)
Player_Script_Name = 'Simulatie Speler'
-- Set name for storage for objects to be recorded
Storage_Name = 'STSIMULATION'
-- ********** END PARAMETERS ***********
-- Check if player is active
Current_Start_Stop_Value = grp.getvalue(Address_Play_Stop)
if Current_Start_Stop_Value == true then
  -- Turn on feedback LED
  -- Get start / stop feedback value
  A_P_S = grp.getvalue(Address_Play_Stop_Feedback)
  if A_P_S == false then
    -- Enable start / stop feedback LED
    grp.update(Address_Play_Stop_Feedback, true)
  end
  -- Check if command is from modus selection
  -- Action on Selecting Modus
  if event.dst == Address_Modus then
    -- Get current script status
    Script_Status = script.status(Player_Script_Name)
    if Script_Status == true then
      -- Disable player script
      script.disable(Player_Script_Name)
    end
    -- Turn off feedback LED
    if A_P_S == true then
      -- Disable start / stop feedback LED
      grp.update(Address_Play_Stop_Feedback, false)
    end
    -- Exit Script
    return
  end
  -- Get Object information
  objectinfo = grp.find(event.dst)
  -- Get simulation module modus value
  modus = grp.getvalue(Address_Modus)
  -- Check if modus value is between allowed range
  if modus >= 1 and modus <= 16 then
    -- Do nothing, move on with scipt
  else
    end
    -- Exit script (also when modus = 0 for recorder off)
    return
  end
  -- Set Player Active
  if modus == 15 then
    -- Get status of player script
    status = script.status(Player_Script_Name)
    if status == false then
      -- Enable player script
      script.enable(Player_Script_Name)
    end
    -- Exit script
    return
  end
  -- Delete all recorded data
  if modus == 16 then
    -- Delete all recorded data from storage
    storage.set(Storage_Name, nil)
    alert('All recorded simulation data is deleted')
    end
    -- Exit script
    return
  end
  -- Make sure events from Address_Modus are not recorded
    end
    -- Exit script
    return
  end
  -- Make sure events are not recorded while recorder is inactive, player is active or deletion mode is selected
  if modus == 0 or modus == 15 or modus == 16 then
    -- Exit script
    return
  end
  -- When modus is 1 to 14 then this will be executed:
  -- Get object last change timestamp to determine recording day
  objecttimestamp = objectinfo.updatetime
  objecttimetable = os.date("*t", objecttimestamp)
  -- Get Modus last change timestamp to determine recording day
  modusinfo = grp.find(Address_Modus)
  modustimestamp = modusinfo.updatetime
  modustimetable = os.date("*t", modustimestamp)
  if modus == 1 then -- Record Today
    if objecttimetable.yday == modustimetable.yday and objecttimetable.year == modustimetable.year then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 2 then -- Record Sonday
    if objecttimetable.wday == 1 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 3 then -- Record Monday
    if objecttimetable.wday == 2 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 4 then -- Record Tuesday
    if objecttimetable.wday == 3 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 5 then -- Record Wednesday
    if objecttimetable.wday == 4 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 6 then -- Record Thursday
    if objecttimetable.wday == 5 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 7 then -- Record Friday
    if objecttimetable.wday == 6 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 8 then -- Record Saturday
    if objecttimetable.wday == 7 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 9 then -- Record Midweek
    if objecttimetable.wday == 2 or objecttimetable.wday == 3 or objecttimetable.wday == 4 or objecttimetable.wday == 5 or objecttimetable.wday == 6 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 10 then -- Record Weekend
    if objecttimetable.wday == 1 or objecttimetable.wday == 7 and (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 11 then -- Record Full Week from Activation
    if (objecttimestamp - modustimestamp) < 604800  then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 12 then -- Record Full Week from Day 1
    if ((modustimetable.yday - modustimetable.wday) + 7) == (updatetimetable.yday - updatetimetable.wday) and (objecttimestamp - modustimestamp) < 604800 then
      -- Continue Script
    else
      -- Exit Script
      return
    end
  elseif modus == 13 or modus == 14 then -- Record Alway
    -- Continue Script
  end
  -- Get previous data from storage if available
  Storage_Data = storage.get(Storage_Name)
  -- Check if storagedata is available
  if Storage_Data == nil then
    -- Create new data table
    Storage_Data = {}
    table.insert(Storage_Data, {updatetime = objectinfo.updatetime, address = objectinfo.address, value = objectinfo.value, recordmodus = modus, lastplayed = os.time(), timelap = (objectinfo.updatetime - modusinfo.updatetime)})
  else
    -- Loop through array and clear to all found items older then selected scope or from other modus in the recorded values
    for index, StorageData in pairs(Storage_Data) do
      -- Check value before write (if enabled)
      if StorageData.recordtime == nil then
         -- Do nothing
      else
        if (os.time() - StorageData.recordtime) > 604800 or StorageData.recordmodus ~= modus then
            -- Delete item
            Storage_Data[index]=nil
        end
      end
    end
    -- Add data to excisting data table
    table.insert(Storage_Data, {updatetime = objectinfo.updatetime, address = objectinfo.address, value = objectinfo.value, recordmodus = modus, lastplayed = os.time(), timelap = (objectinfo.updatetime - Storage_Data[#Storage_Data].updatetime)})
  end
  -- Write new data back to storage
  storage.set(Storage_Name, Storage_Data)
  log (Storage_Data)
else
  end
  end
end
-------CREATE RESIDENTIAL SCRIPT--------------
-- Simulation Module Version 2.0 - Player Part
-- Set storage name for recorded objects
-- Check object if object value is changed before write (same value = no write)
Check_Object_Changed = false
-- Set random value in seconds to make switching time not exactly the same time as recording time so you won't see its automaticly send every day the same time.
Sec_Random = 1800 -- makes bandwidth of 30 minutes when recording will be played, set to 0 will disable the random function and objects will be played on same time as recording.
-- Get data from storage if available
-- Set Data table changed to false (save data only when changes are detected)
Data_Table_Changed = false
   -- Exit Script
   return
else
   -- Sort table by updatetime
   table.sort(Storage_Data, function(first,last) return first.updatetime < last.updatetime end)
   -- Set current time as timestamp for calculation
   timestamp = os.time()
   -- Set counter to 0
   counter = 0
   -- Loop through array and write to all found addresses in this recording the values
   for index, StorageData in ipairs(Storage_Data) do
      ::ObjectStart::
      -- Create random value to play object not exactly on same time but in a scope of 30 minutes from that time.
      random = math.random(0, Sec_Random)
      -- Create table from current time to get wday and yday
      currenttimetable = os.date("*t", os.time())
      -- Create table from lastplayed to get wday and yday
      lastplayedtable = os.date("*t", StorageData.lastplayed)
      -- Check if recordmodus is available
      if StorageData.recordmodus == nil then
         -- Do nothing, move to next object because this object has no modus info.
         counter = counter + StorageData.timelap
         goto NextObject
      else
         modus = StorageData.recordmodus
      end
      -- Check if weekday matches with recording (not for modus 1 and 14)
      if modus ~= 1 or modus ~= 14 then
         if currenttimetable.wday == lastplayedtable.wday then
            -- Day matches, move on with script
         else
            -- Do nothing, move to next object because this object doesn't mach day of playing.
            goto NextObject
         end
      end
      if Check_Object_Changed == true then
         -- Get current object value
         value = grp.getvalue(StorageData.address)
         -- Check if value is the same
         if value == StorageData.value then
            -- Do nothing, move to next object because this object aready is set to wanted value.
            goto NextObject
         end
      end
      -- Selected actions by modus
      if modus == 14 then -- Play Direct (for testing your recordings)
         -- Check if this is first object from table
         if index == 1 then
            if (timestamp + StorageData.timelap) &lt= os.time() then
               -- Move to write to object part
            else
               -- Slow looping down when object does not meet requirements (only for modus 14)
               os.sleep (1)
               -- Try again
               goto ObjectStart
            end
         else
            if ((timestamp + StorageData.timelap) + counter) &lt= os.time() then
            else
               os.sleep (1)
               -- Try again
               goto ObjectStart
            end
         end
      end
      -- ** Write to object part ** (all previous conditions are true)
      -- Write function for modus 1 to 13 to use when conditions are true
      function WritetoObject_Modus_1_to_13()
         -- Calculate if object is at least 12 hrs old (to make sure it won't be played again the same day)
         if StorageData.lastplayed - os.time() >= 43200 then
            timedifference = os.time() - StorageData.updatetime
            -- Perform modulo 86400 to clear all passed days from time difference and keep time difference < 24hrs
            result = timedifference % 86400
            -- Calculate seconds to complete minutes past
            result = math.floor(result / 60)
            -- Calculate random to complete minutes to calculate
            random = math.floor(random / 60)
            -- Create a random time between 30 minutes to meet condition to play
            if result >= (1440 - random) then -- 1440 = 60 min * 24 hrs
               -- Write address to wanted value
               grp.write(StorageData.address, StorageData.value)
               -- Update timestamp last played
               StorageData.lastplayed = os.time()
               Data_Table_Changed = true
            end
         end
      end
      -- Write function for modus 14 to use when conditions are true
      function WritetoObject_Modus_14()
      end
      -- Determine what objects to play on recording conditions
      if modus == 1 then -- Today
      elseif modus == 2 and currenttimetable.wday == 1 then -- Sunday
      elseif modus == 3 and currenttimetable.wday == 2 then -- Monday
      elseif modus == 4 and currenttimetable.wday == 3 then -- Tuesday
      elseif modus == 5 and currenttimetable.wday == 4 then -- Wednesday
      elseif modus == 6 and currenttimetable.wday == 5 then -- Thursday
      elseif modus == 7 and currenttimetable.wday == 6 then -- Vriday
      elseif modus == 8 and currenttimetable.wday == 7 then -- Saterday
      elseif modus == 9 and (currenttimetable.wday == 2 or currenttimetable.wday == 3 or currenttimetable.wday == 4 or currenttimetable.wday == 5 or currenttimetable.wday == 6) then -- Midweek
      elseif modus == 10 and (currenttimetable.wday == 1 or currenttimetable.wday == 7) then -- Weekend
      elseif (modus == 11 or modus == 12 or modus == 13) and currenttimetable.wday == lastplayedtable.wday then -- Full Week from Activation, Full Week from Day 1 and Always
      elseif modus == 14 then -- Play direct
      end
      ::NextObject::
   end
   -- Write changed table back to storage when timestamp lastplayed is changed during playing
   if Data_Table_Changed == true then
   end
end
sesa149896_brid
Posted: ‎2017-08-18 12:35 AM
Many Thanks
