Multitouch Pro Fan speed control
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Multitouch Pro Fan speed control
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2022-02-01 04:32 AM . Last Modified: ‎2024-07-14 11:45 PM
846
I have Gree VRV system while its fan speed 1Byte value from 1 to 7, While in touch Pro its percentage!
any idea how to solve this, preferred without script.
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: ‎2022-02-06 11:07 PM
837
Dear IC-Systems,
I forgot to answer your topic ... sorry!
I didnt found a solution to realize your topic with normal KNX-Products in an efficient way.
Taken the assumption that you need this solution for several rooms and not only a single one I recommend to solve it with a script in W4K (LSS100100) or spaceLYnk (LSS100200).
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
838
Dear IC-Systems,
Kind regards
Thomas
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2022-02-07 01:51 AM . Last Modified: ‎2022-02-07 02:11 AM
1
832
Thank you @Thomas_Rohde
I appreciate if a solution comes in next firmware.
one of the TS that I've seen and solve this issue, adding a parameter in the ETS like this:
Edit: and  the 1byte object is value instead of %; this may solve the issue, what you think about this @Thomas_Rohde
Another parameter I hope to be improved in the TS is the RGB control this is also need a script
some thing like this will be amazing
I make these feedbacks to see the TS more powerful and more competitive in the market.
With best Regards,
Best Regards,
Thomas_Rohde
Sisko
Posted: ‎2022-02-08 10:59 PM
Hello IC-systems,
many THANKS for your valueable feedback and concrete improvement proposals.
Very much appreciated! 😊
Kind regards
Thomas
