Long delayed loading the homepage of homeLynk/spaceLynk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Long delayed loading the homepage of homeLynk/spaceLynk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Raul_Vasvari
Lieutenant JG Raul_Vasvari Lieutenant JG
Lieutenant JG
Posted: ‎2016-06-21 05:45 AM . Last Modified: ‎2024-07-14 11:55 PM
611
When you want to connect to homelynk from a smartphone or tablet it takes approximately 40-50 seconds to load the home page.
Can someone tell me if and what can be done to reduce this time?
thank you
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Thomas_Rohde
Sisko
Posted: ‎2016-06-21 08:24 AM
583
Hello Raul,
first of all I need to say that your case is normal. It should go really quickly.
1. Do you face this behaviour with other websites (maybe other webserver device within your network) as well
or is it only by the HL access.
2. Have you cleared up your browser cache?
3. Do you have big pictures integrated into your visualization?
4. What is your network-performance in general?
5. Do you face this issue within your local network or by external VPN/DYNDNS?
kind regards
Thomas
Kind regards
Thomas
Application Design Engineer
Raul_Vasvari
Lieutenant JG
Posted: ‎2016-06-27 04:29 AM
583
Hello Thomas,
1.       we have this problem only with HL
2.       yes, we cleared browser cache
3.       no, there are not big pictures integrated in visualisation
4.       there are not a problem with network, other more complex web page start quickly
5.       we have the same problem inside and outside of local network
kind regards
Raul
Thomas_Rohde
Sisko
Posted: ‎2016-06-27 04:47 AM
Hi Raul,
Ok, next tries
6. Have you checked the networksettings of HL? Maybe something is missing there (e.g. default gateway or similar)
7. Have you exchanged the device against an other HL? Means, do you face the same issue with an other HL but same project?
8. Have you tried to create a small network (HL, Switch/Router, your PC) to verify if this behaviour is still the same?
9. Have you made a backup and performed later on a factory-reset
10. Please sent me a backup of your project, the serialnumber of your HL, the used FW-Version, the browser which you are using etc.
Kind regards
Thomas
Kind regards
Thomas
