KNX -DALI-Gateway  MTN6725-0004 Address Changing Issue
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • KNX -DALI-Gateway  MTN6725-0004 Address Changing Issue
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Dharmik
Dharmik
Cadet
Posted: ‎2022-02-21 02:24 AM . Last Modified: ‎2024-07-14 11:44 PM
1118
     I Have KNX DALI Gateway  MTN6725-0004 , 2 Channel Dali Gateway. I Updated It With Firmware update 0.2 Release 1 So Its Now DALI Tunable.
I Am Facing Problem When Electric Mains Power Goes Out And When Its Come Back My Lights Drivers Address Being Change ( Driver Did not Get Assign Address, It Get Different Address ) So I Have To Do Reconfigured Each And Every time.
Any One Has Faced Issue Like This ?
Kindly Guide How Resolve This Issue
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (2)
  • dali
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2022-02-21 11:28 PM
Yes,
most often:
- bad product on line
- shortcircut on line
Smarthome & Smartbuilding Expert
Heribert_Dölger
Commander
Posted: ‎2022-03-11 12:26 AM
1082
The DALI gateway does not perform any addressing process after an power outage. I would rather assume the ECGs are loosing their addresses due to the power cut. You might check the communication on the DALI line with the help of a DALI monitoring tool (like Tridonic masterCONFiGURATOR) connected with a DALI/USB interface and see if there is any re-addressing. The tool would also allow to check the addresses.
domotiqa
Lt. Commander
Posted: ‎2022-06-02 01:14 AM
I agree, try reassigning address on DALI ECG. Then do power off/on of the ECG. Try again to see if they loose heir adress. Should fix most error
