Is there any way to reset KNX device to factory defaults?
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Is there any way to reset KNX device to factory defaults?
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa210173
sesa210173 Schneider Alumni (Retired)
Posted: ‎2014-06-25 03:05 AM . Last Modified: ‎2024-07-15 12:07 AM
1378
In one of our projects , Our SI kept password for the project as well as password for BCU. Unfortunately they forgot the credentials of project and BCU.
Is there any method, to reset the device to factory defaults?
Regards
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Heribert_Dölger
Commander
Posted: ‎2014-07-03 12:21 AM
1330
You couold try a maste rest. To do so remove power from the device. Press programming button and keep it pressed. Reconnect power to the device and keep theprogrammng button pressed for another 5 seconds.
Good luck!
Replies 4
Posted: ‎2014-07-01 07:46 PM
Hi Ramesh
Can you try upload on the menu?
Heribert_Dölger
Commander
1331
Good luck!
sesa210173
Posted: ‎2014-07-03 12:35 AM
Thanks alot Heribert....I will update you once I done this process.
sesa210173
Posted: ‎2014-07-03 03:12 AM
Hi Heribert,
This master reset procedure is working perfect.. Thanks a lot again.
Regards
