Is it better to use many short scripts or fewer long scripts?
SpaceLogic KNX Forum
Select a Country
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Is it better to use many short scripts or fewer long scripts?
Thomas_Rohde
Thomas_Rohde Champion
141
Erwin-vd-Zwart
Erwin-vd-Zwart Champion
65
Heribert_Dölger
Heribert_Dölger Leader
36
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
ld94
ld94
Contributor
Posted: ‎2022-05-27 02:50 AM . Last Modified: ‎2024-07-14 11:44 PM
1240
Hello all!
I need to divide in more addresses a 6-byte value and I should do this operation for around 150 points through a script. My question is: Is it better to use many short scripts or fewer long scripts?The scripts are resident (60 seconds) and I'd like to create 1 script per Gateway DALI with all the lamps inside but I don't know if is better this way or creating a single script per lamp.
Do you guys have any suggestions?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
  • Scripts
IC_Systems
IC_Systems
Mentor
Posted: ‎2022-05-29 12:49 AM
I don't have a log scripting journey.
But for 150 points its easier to edit, maintain, optimize,... if you have one resident script, or you could use functions and event based script, but notice that not all of the 150 objects triggered in the same time, while this will load the server.
Another point you should take in consideration is the response time you want to achieve, if you dont have any delay inside your script then one loop will take 150*60 sec.
this is my opinion, waiting for experts explanation:)
Best Regards,
IC_Systems
IC_Systems
Mentor
Best Regards,
Erwin-vd-Zwart
Champion
Posted: ‎2022-05-30 01:15 AM
1228
Can you elaborate what the 6 byte value is used for so i can get an impression of your needs?
When the values are changing on high frequency you might need a resident script, when this is not the case a single event script with tags attached to your objects will do just fine, but when all 150 objects are changing at the same time you will have a peak in the CPU load, so without more info i cannot give a good answer..
ld94
ld94
Contributor
Posted: ‎2022-06-15 02:06 AM . Last Modified: ‎2022-06-15 02:07 AM
@Erwin-vd-Zwart @IC_Systems thank you for replying.
I'm using the 6-bytes data to read the alarms and status of some emergency lamps.
I'll unpack the 6-bytes into 8 different addresses.
Right now I've created for every lamp a single resident script (since the reading needs to be continous) so I've created around 75 resident scripts with a 60s loop on 2 different spacelynks.
