IP camera visualization with Chrome
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • IP camera visualization with Chrome
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa356649_brid
Ensign sesa356649_brid Ensign
Ensign
Posted: ‎2017-01-03 07:49 AM . Last Modified: ‎2024-07-14 11:54 PM
948
IP camera visualization with Chrome, seen  print screen below,  Is this a known issue?
The same problem occurs with 7'' U.motion screen !
With firefox or safari, everything works properly
Does someone know how to solve this problem?
Best Regards
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
sesa356649_brid
Ensign
Posted: ‎2017-02-15 02:56 AM
Many thanks Thomas, Erwin,
Br
Replies 5
Thomas_Rohde
Sisko
Posted: ‎2017-01-03 11:36 PM
881
Hi Jean-Luc,
I quickly checked your topic on my HL and faced the same issue but it seems that you selected the wrong function within HL.
I am not a specialist within video-formats but it seems to me that this is only a picture-format *.cgi. (Computer Generated Imagery).
Solution:
1. Select a real video-path with the ending .mjpg like "http://192.168.0.120/mjpg/video.mjpg"
2. Select within the HL-Admin-Area the function "Frame" instead of "Camera". Because there you can select a "refresh-rate" in seconds
and than it is working as well (somehow because it is not a fluent video only an updated picture according to the configured "refresh-rate".
Kind regards
Thomas
Kind regards
Thomas
Application Design Engineer
sesa356649_brid
Ensign
Posted: ‎2017-01-04 07:34 AM
881
Hi Thomas,
Thanks for your help, sorry, yesterday I posted a wrong print screen, it seems that the 'Frame" trigger the camera view, seen prints screen below
the first point alone doesn't open the camera view , but when combining the both, view goes open ?
Why do this problem occur only with "Google chrome"  ?
Best  Regards
Thomas_Rohde
Sisko
Posted: ‎2017-01-04 10:45 PM
881
Hi Jean-Luc,
Sorry but I do not understand fully your answer?! Are you using the *.mjpg url within the frame? Please sent me your project so that I can see more in detail what is ongoing.
Kind regards
Thomas
Kind regards
Thomas
Erwin-vd-Zwart
Janeway
Posted: ‎2017-01-05 05:41 PM
881
Camera frame is a img container.
By default a img container does not support basic authentication.
Only way to solve this is to create a widget with a iframe.
The result will look almost the same and with some extra css you can make it look identical.
Another option is to make a hidden page with iframe, when this is loaded the authentication is not needed anymore for the camera img object.
BR,
Erwin van der Zwart
sesa356649_brid
Ensign
Br
