Hi![]()
I've have some Philip Hue lamp, connect to KNX via Homelynk.
I've want to dim them from a KNX push button (4 bit object)
Is there someone there has made a solution how to dim ?
Switch on/off and 0 - 100% is show in AN020 but not 4 bit object
BR
Tommi Jensen
Hi Pawel
Thanks for the answer, there was a small bug in the script, but it working just fine now, see below ![]()
Br.
Tommi
--oprettes som permanent script med 0s
objekt_in_4b = grp.getvalue('1/0/4')
objekt_out_1B = '1/0/6'
skok = bit.band(objekt_in_4b, 0x07)
if skok ~= 0 then
brighter = bit.band(objekt_in_4b, 0x08) ~= 0
aktualna = grp.getvalue(objekt_out_1B) ------ This was corrected from grp.getaktualna to grp.getvalue
if brighter then nastepna = aktualna + 5
else nastepna = aktualna - 5
end
nastepna = math.min(nastepna, 100)
nastepna = math.max(nastepna, 0)
if aktualna ~= nastepna then
grp.write(objekt_out_1B, nastepna)
end
end
os.sleep(0.25)
Posted: 2017-07-14 01:57 AM
I'm not sure how fast we can send information to hue lamps via homeLYnk, but below you'll find a simple script which converts dimming object to value object (Resident script with interval 0s):
obiekt_in_4b = grp.getvalue('6/0/1')
obiekt_out_1B = '6/0/2'
skok = bit.band(obiekt_in_4b, 0x07)
if skok ~= 0 then
brighter = bit.band(obiekt_in_4b, 0x08) ~= 0
aktualna = grp.getvalue(obiekt_out_1B)
end
grp.write(obiekt_out_1B, nastepna)
end
end
os.sleep(0.25)
Hi Pawel
Br.
Tommi
if skok ~= 0 then
end
end
end
os.sleep(0.25)
