Homelynk Trends Limits
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Homelynk Trends Limits
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa356649_brid
Ensign sesa356649_brid Ensign
Ensign
Posted: ‎2017-06-15 02:58 AM . Last Modified: ‎2024-07-14 11:52 PM
838
What are the "trendlogs" limits ?
  1. memory limits ?
  2. number of data points ?
  3. Duration of data storage ( number of years ) ?
Best regards
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2017-06-29 01:36 AM
Hello Jean-Luc,
It is working like this:
1. You can add trend logs with different resolution (different size of max. data, which can be stored) and once you are close to 32 MB, then you get error message and you are not able to add more trends anymore. When you create Trend log, you can see column "Log Size", this information is memory usage for this trend, when it has stored maximum data points (max. is 4136KB).
2. If trend logs save maximum data points, definned for each trend log, all those trend logs have memory usage 32MB in homeLYnk/spaceLYnk.
So when you reach the limits, it is mean only your Trend logs are full and you are forced to export, back up those trends and create new one.
Regards
David
David_Navratil
Lt. Commander
Posted: ‎2017-06-28 12:57 AM
807
Hello Jean-Luc,
1) 32MB
2,3) It depend on configuration, once your trend logs size will be close to 32MB you will get error message and you will not be able to add new Trend log.
Regards
David
sesa356649_brid
Ensign
Posted: ‎2017-06-29 12:43 AM
807
Hello David,
What happen whit the existing trend logs when the limit is reached in HL ?
Best regards
David_Navratil
Lt. Commander
Hello Jean-Luc,
Regards
David
