Homekit reset
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Homekit reset
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_DĂślger
Commander Heribert_DĂślger Commander
31
Back to SpaceLogic KNX Forum
flo
Ensign flo
Ensign
Posted: ‎2025-03-31 02:52 AM
1364
Homekit reset
I am having a major problem with the HomeKit plug-in as I cannot reset it. therefore HomeKit tells me that I cannot connect as the bridge is connected to another house. I have tried to switch off the plugin, restart spacelynk and switch back on the HomeKit plugin. unfortunately the same code for pairing remains which HomeKit will not accept. any ideas?
thank you in advance
  • SpaceLYnk
Replies 9
Thomas_Rohde
Sisko
Posted: ‎2025-04-02 01:21 AM
Hello Flo!
For me to undertstand your topic correctly ...
Did you copied a project backup for another project and this "new project" you want to link with a new bridge while keeping the other connection with the former bridge?
Kind regards
Thomas
Application Design Engineer
flo
Ensign flo
Ensign
Posted: ‎2025-04-02 10:32 PM
Dear Thomas,
I‘ll explain a bit better:
Preset:
I have SpaceLynk up a running. As I am an Apple guy the application to use the SpaceLynk in combination with HomeKit is a feature I was really looking for.
I set up everything, connected the SpaceLynk as bridge into a home, home base is an Apple TV. Everything was working nicely an as expected. Until it froze. Normally nothing serious, you restart the Apple TV the bridge and everything works again.
But this time something went wrong, better I could not get the system to work again.
so I disconnected the SpaceLynk as bridge from the Apple TV. I restarted the Apple TV. But I cannot set up the SpaceLynk as bridge anymore. It says: It’s connected with another home.
I had this problem before in a different environment, and the only thing which normally works is to reset this bridge.
And this is what I am trying to achieve.
what did I try so far: I even de-installed the HomeKit application to start from scratch. But after restarting SpaceLynk and installing the Homkit application, all the settings und devices where back (so no reset) and therefore no connection the the Homebase possible. Same error: “already connected to another home”
Did my explanation help now?
best regards
flo
Thomas_Rohde
Sisko
Posted: ‎2025-04-04 12:10 AM
Hi Flo,
many THANKS for the detailed explaination.
I need to ask again. Did you tried to use this trash bin button?
Kind regards
Thomas
flo
Ensign flo
Ensign
Posted: ‎2025-04-04 11:03 PM
Hi Thomas,
Thank you so much for staying on the topic.
I used the install “trashcan” to get rid of the HomeKit installation.
After reinstalling everything was back, which already made me worry, and I still could not connect.
I could give it I try, I was guessing that the trashcan you mentioned only erases single entries…
best regards
IMG_0629.jpeg.
Thomas_Rohde
Sisko
Posted: ‎2025-04-06 11:31 PM
Hi Flo!
Ok, please give it a try and if its still doesnt work then we need to open a ticket so that it is properly handled by our customer care team.
Kind regards
Thomas
flo
Ensign flo
Ensign
Posted: ‎2025-04-07 12:07 AM
dear Thomas,
using the trashcan you mentioned, it produces a new pairing number for Homekit. By the end of the week, I can try if it works now, I guess it will. I will report. Fingers Crossed
Thomas_Rohde
Sisko
Posted: ‎2025-04-09 12:58 AM
1240
Hi Flo!
Sounds promising đŸ˜€
And YES, please let us know if it works.
Kind regards
Thomas
flo
Ensign flo
Ensign
Posted: ‎2025-04-11 10:14 PM
Dear Thomas, dear all,
receiving a new pairing number by using the trashcan icon is the solution! Thank you Thomas for the help, I have to admit the misleading trashcan icon made me think I would trash the setup, instead of resetting it. And therefore I did not even try.
everything back up and running!
thank you
Thomas_Rohde
Sisko
Posted: ‎2025-04-14 12:25 AM
Perfect! Many THANKS for the confirmation đŸ˜Š
Enjoy the homekit functionality!
Kind regards
Thomas
Terms & Conditions Privacy Notice Change your Cookie Settings Š 2025 Schneider Electric
