HomeLynk vs SpaceLynk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • HomeLynk vs SpaceLynk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa57526_bridg
sesa57526_bridg Schneider Alumni (Retired)
Posted: ‎2014-07-02 10:49 AM . Last Modified: ‎2024-07-15 12:06 AM
6
2435
What are the main differences between HomeLynk and SpaceLynk?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
sesa46294
Ensign sesa46294 Ensign
Ensign
Posted: ‎2014-07-29 12:12 AM
1
2258
The first difference between homeLnk and spaceLYnk is the number of BACnet points that the controlleur managers as BACnet server; homeLYnk is limited by firmware to 150 points and spaceLYnk is recommended to 500 points even if this is not limited by firmware.
Real limitation is depending from what the controller is doing and how it is used (if only used as gateway without any logic or anything else to process, will be more).
Current indication is given in User Manual and related to CPU load not to achieve.
We are currenly doing tests to make recomandations
THere are some projects like one I'm aware of where 3000 points need to be managed and there they put 5 spaceLYnk.
Replies 6
sesa296387
sesa296387 Schneider Alumni (Retired)
Posted: ‎2014-07-07 07:12 AM
1
2258
Hi Sabrina,
The only difference today is that homeLYnk is limited to 150 BACnet points and spaceLYnk is not.
And as their names suggest, homeLYnk is more for residential buildings and spaceLYnk is for commercial, althougt there is no force to hold the integrators to use it within the specific building segment.
sesa46294
Ensign
Posted: ‎2014-07-09 12:26 AM
homeLYnk is dedicated to residential and will stay there in terms of new features to come in the fimware.
spaceLYnk is dedicated to commercial and here we are focusing first on architectures leveraging all the different offers from Partners (eg:smartlink, Canalis iBusway, Smart Panel,..) and features will also be focused in this segment like for instance connectivity with SBO through BACnet or SLL
deodato
deodato Schneider Alumni (Retired)
Posted: ‎2014-07-28 05:46 AM
2
2258
What is the real limitation of SpaceLYnk regarding the BACnet objects? I understand that there is no limitation in theory,but this is a strong sentence to talk to a client, any kind of test was made and ensure, like 5k objects for instance?
thanks for the help
sesa46294
Ensign
1
2259
deodato
Posted: ‎2014-07-31 11:45 AM
Hello Jean-Christophe, thanks for your answer, I will use this number to answer any question in this subject, since its tested and validated...
best regards
sesa70584_bridg
sesa70584_bridg Schneider Alumni (Retired)
Posted: ‎2014-10-22 06:54 AM
Hello!
In addition to what was said, please see the application use cases consolidated in 1 document for homeLYnk (residential) and spaceLYnk (commercial)
enjoy reading and share with yoru customer !
best regards,
Karina.
