HomeLYnk - Timestamp issue for Energy Counter
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • HomeLYnk - Timestamp issue for Energy Counter
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
DK-Michael
Commander DK-Michael Commander
Commander
Posted: ‎2015-12-22 04:19 AM . Last Modified: ‎2024-07-14 11:56 PM
2330
I have found a problem in the HomeLYnk when using the trend logger with counter values.
The data from "today" is marked as "yesterday" in the trends when viewing the data. I expect that this happens because the summations is made at midnight and therefore timestamped with the day after.
I have attached two pictures to show what I mean. As you can see on one picture, the total sum of Nov 18 is 3.2kWh but this is logged as Nov 19 on the "monthly" picture.
Does anyone have a solution to this?
//Michael
________________________________
Michael Johansen
Solution Architect
M +4528991535
E michael.johansen@se.com
LinkedIn https://www.linkedin.com/in/mich4el/
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (5)
  • energy server
  • gateway
  • gateways
  • homelynk
  • spacelynk
Erwin-vd-Zwart
Janeway
Posted: ‎2015-12-24 12:49 PM
5
2213
Hi Michael,
This is a know item and should be fixed in FW 1.4.
BR,
Erwin
Replies 9
Erwin-vd-Zwart
Janeway
5
2214
Hi Michael,
BR,
Erwin
DK-Michael
Commander
Posted: ‎2015-12-27 11:47 PM
2213
Hi Erwin
Thanks for the response. Is there an estimated time for the new firmware and will it fix the already logged values?
BR, Michael
Michael Johansen
Solution Architect
M +4528991535
sesa189443
sesa189443 Schneider Alumni (Retired)
Posted: ‎2016-01-04 05:46 AM
3
2213
Hi Michael
Some time in February and yes it will fix old trends. There will be new trend engine and old trends will be converted to new one during upgrade. We will also have lower sampling rate.
Regards
Daniel
DK-Michael
Commander
Posted: ‎2016-01-10 10:37 PM
2213
Hi Daniel
Thanks! That sounds great. Will we also get an easy way to export the data from the trends to some external system. E.g. if a customer have used the HomeLYnk/SpaceLYnk as a small energy server but wants to migrate to PME?
Kind regards, Michael
Michael Johansen
Solution Architect
M +4528991535
sesa189443
Posted: ‎2016-01-14 02:48 AM
1
2213
This you can do already by scripts but in new fw we will need new script as data will be stored in different place. In new FW there will be new possibility we integrated cloud connector and via cloud we can export data to 3rt party as csv. For now this will be available in France but other countries can join on request.
DK-Michael
Commander
Posted: ‎2016-01-14 07:26 AM
Hej Daniel
Can you share a template script for this with me?
Best regards, Michael
Michael Johansen
Solution Architect
M +4528991535
Erwin-vd-Zwart
Janeway
Posted: ‎2016-01-15 05:27 AM
Hi Michael,
Use this for reading trends with script and export to CSV on internal FTP server: You need to enable the server first and check credentials and IP address in the scrip (default ftp:ftp)
require('socket.ftp')
require('genohm-scada.trends')
-- ftp file
ftpfile = string.format('ftp://ftp:ftp@192.168.10.200/' .. 'All trends last month data export' .. '_%s.csv', os.date('%Y-%m-%d_%H-%M', timestamp))
-- csv buffer
buffer = {}
-- Get all trend names from DB
trends_table = db:getall('SELECT name FROM trends ORDER BY name DESC')
for _, trend_names in ipairs(trends_table) do
  -- Get current timestamp
  timestamp = os.time()
  now = os.date('*t', timestamp)
  trend_name = trend_names.name
  -- Get last month for data and determine number of days in this month
  trenddatamonth = trends.fetch(trend_name, 'month', now)
  -- Add to buffer
  table.insert(buffer, '"Average usage a month (' .. trend_name .. ')"')
  -- Add empty line
  table.insert(buffer, '""')
  -- Add header
  table.insert(buffer, trend_name .. ',"Day","Average day value"')
  for _, row in ipairs(trenddatamonth) do
    -- format csv row
    csv = string.format('%q,%q,%q', "", "" .. string.format("%02d", row[1]) .. "-" .. string.format("%02d", now.month) .. "-" .. now.year, row[2])
    -- add to buffer
    table.insert(buffer, csv)
  end
  -- Add empty line
  table.insert(buffer, '"Average usage a day (' .. trend_name .. ')"')
  -- Add empty line
  for i = 1, now.day, 1 do
    now.day = i
    average_value = 0
    trenddata = trends.fetch(trend_name, 'day', now)
    -- Add header
    table.insert(buffer, trend_name .. ',' .. string.format("%02d", i) .. '-' .. string.format("%02d", now.month) .. '-' .. now.year .. ',"Average hour value"')
    for _, row in ipairs(trenddata) do
      -- format csv row
      csv = string.format('%q,%q,%q', "", "" .. string.format("%02d", (row[1]-1)) .. ":00:00", row[2])
      -- add to buffer
      average_value = average_value + row[2]
    end
    -- Add empty line
    table.insert(buffer, "")
    -- add to buffer
    table.insert(buffer, "Average value month (" .. string.format("%02d", now.month) .. "-" .. now.year .. ")," .. trenddatamonth[i][2])
    -- Add empty line
  end
end
-- upload to ftp only when there's data in buffer
if #buffer > 1 then
  result, err = socket.ftp.put(ftpfile, table.concat(buffer, '\r\n'))
  -- error while uploading
  if err then
    alert('FTP upload error: %s', tostring(err))
  end
else
  log('No data found inside trend ' .. trend_name)
end
Good luck (:
BR,
Erwin van der Zwart
Erwin-vd-Zwart
Janeway
Posted: ‎2016-01-15 05:31 AM
1
2213
Hi Michael,
Use this script to read and export a single trend :
trend_name = 'Your trend name to export'
-- ftp file
ftpfile = string.format('ftp://ftp:ftp@192.168.10.200/' .. trend_name .. '_%s.csv', os.date('%Y-%m-%d_%H-%M', timestamp))
log(trenddatamonth)
-- csv buffer
buffer = { '"Average usage a month"' }
-- Add empty line
-- Add header
  -- format csv row
  -- add to buffer
end
-- Add empty line
table.insert(buffer, '"Average usage a day"')
-- Add empty line
  now.day = i
  average_value = 0
  -- Add header
  -- format csv row
    -- add to buffer
  end
  -- Add empty line
  -- add to buffer
  -- Add empty line
end
if #buffer > 1 then
  if err then
  end
else
end
BR,
Erwin van der Zwart
DK-Michael
Commander
Posted: ‎2016-01-17 11:42 PM
Hi Erwin
That's awesome! Thanks a lot! I will try it later this week (:
BR, Michael
Michael Johansen
Solution Architect
M +4528991535
