Continue
  • My Subscriptions
  • Events
HL acting as a IP-router
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • HL acting as a IP-router
Thomas_Rohde
Thomas_Rohde Champion
143
Erwin-vd-Zwart
Erwin-vd-Zwart Champion
66
Heribert_Dölger
Heribert_Dölger Leader
37
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
esteve_budia
esteve_budia Mentor
Mentor
Posted: ‎2014-09-18 09:05 AM . Last Modified: ‎2024-07-15 12:05 AM
1357
Is it possible this arquitecture?
PC1 and PC2 must be connected to all areas while HL continues routing Area1 to area 2 and 3.
THX
4703
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Replies 5
sesa299442
sesa299442 Leader
Leader
Posted: ‎2014-09-19 12:29 AM
4
1293
Yes, this is posible.
Tommi_Jensen
Tommi_Jensen Contributor
Contributor
Posted: ‎2014-09-30 07:52 AM
1293
Hi Tomas
Can you show how to setup the HL as line coubler, with line coubler adress 1.4.0
sesa299442
sesa299442 Leader
Leader
Posted: ‎2014-10-01 12:46 AM
1293
Tommi,
note that your main line must be KNX IP.
Go to homeLYnk system configuration. Select "Nework" >> "KNX connection".
Then set
     Mode: EIBnet/IP Routing
     KNX address: address of your coupler (1.4.0)
     KNX IP features: CHECK
     Multicast IP: 224.0.23.12 (default)
     Multicast TTL: 1 (default)
     Maximum telegrams in queue:100 (default)
On the other 2 card you can set the KNX>>IP and IP>>KNX filter rules.
Regards
Tomas
Tommi_Jensen
Contributor
Posted: ‎2014-10-02 10:38 PM
1293
Hello Tomas
I've can not get it to work, from ETS 4 , I've can not download from ETS 4 and it can not scan the line, is the Homelynk not supporting this?
4800when I've use this setting and take this homelynk connection in ETS4 then I've can download to line 4.
4801If I've take this connection in ETS 4' it will not work.
BR
Tommi
sesa299442
sesa299442 Leader
Leader
Posted: ‎2014-10-03 12:21 AM
Hello Tommi,
you are right!
There are three main option you may need to set. Let me explain it clearly.
1) TP-UART + KNX IP features (unchecked) - it communicates only on TP, all KNX IP telegrams are blocked
2) TP-UART + KNX IP features (checked) - it communicates both on TP and IP
3) EIBnet/IP routing - it communicates on IP only
So for your case, you should use the option n.2.
BR
Tomas
