Custome Value Widget for Wiser App
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Custome Value Widget for Wiser App
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-08-13 07:34 AM
421
Hello Dears,
I have a device with 8bit on/off control
1 == off
2 == on
is there a widget compataple witht the wiser app that I can use?
Best Regards,
  • Mobile App
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2025-08-27 01:15 AM
2
387
Hi IC_Systems!
Believe, I miss them strongly since the beginning.
BUT, there is light at the end of the tunnel 🙂
The info widgets are currently in field test. Means in the next official app release they will be part of it.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
2
388
Hi IC_Systems!
Kind regards
Thomas
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-08-27 01:38 AM
385
thank you @Thomas_Rohde
but info widget seems like status, but is it contain control command also?
Best Regards,
Thomas_Rohde
Sisko
Posted: ‎2025-08-27 02:12 AM
Yes you are right. It is "Info Widget" means no control just status.
For your case I think you can work with a tiny script which converts 1bit switch information into the needed 8bit one.
Kind regards
Thomas
