Controlling AC Unit with Wiser App
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Controlling AC Unit with Wiser App
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Hussein__Ali
Hussein__Ali
Cadet
Posted: ‎2025-04-10 04:50 AM
1126
Hello there,
I'm currently working with a 4” touch screen and Intesis gateway for air conditioning control. Additionally, we are attempting to configure a thermostat using the Wiser LSS100100. However, we’ve encountered several issues during the setup process.
The available objects within the thermostat widget on Wiser appear to be entirely different from what we expected, because the used objects in the getway and and the touchscreen are shown in attached pic. 1
the objects for wiser thermostat are in pic. 0
1.there is no on/off object.
2.What are the objects for HVAC control modes (heat, cool, fan only, dry).
3.
How do I change the fan speed? I tried configuring it, but the app displays different values.
4.im not sure if the objects are opposite because the as ex fan speed and fan speed feedback wasn't working but when change them there are only reading the value from the touchscreen and not sending any speed just receiving.
Thank you for your support.
  • Thumbnail of Wiser for KNX : logic controller
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
View products (2)
  • Wiser for KNX
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-04-12 11:06 PM . Last Modified: ‎2025-04-12 11:09 PM
Hello @Hussein__Ali
For Operation Modes Heat, Cool, Fan, ... you can use "General / use custom modes" in wiser thermostat widgets.
For setpoint and Fan speeds try this
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Hello @Hussein__Ali
Best Regards,
Hussein__Ali
Hussein__Ali
Cadet
Posted: ‎2025-04-26 10:57 AM
thank you very much, it worked for operation modes, but it looks different in the wiser app. but it works.
