Connect wiser for knx with Fronius Gen24 inverter
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Connect wiser for knx with Fronius Gen24 inverter
Thomas_Rohde
Sisko Thomas_Rohde Sisko
125
Erwin-vd-Zwart
Sisko Erwin-vd-Zwart Sisko
56
Heribert_Dölger
Lt. Commander Heribert_Dölger Lt. Commander
30
FZetina
Lt. Commander FZetina Lt. Commander
28
Back to SpaceLogic KNX Forum
1991Stefan
Crewman 1991Stefan
Crewman
Posted: ‎2025-02-16 03:49 AM
754
Hello Is there a way to connect the wiser for knx with the Fronius Gen24 and a storage device from BYD and display it in the Touch 3
  • Mobile App
  • SpaceLYnk
Replies 7
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-02-17 07:06 AM
730
Hello @1991Stefan
you could do that by using Modbus communication protocol.
Best Regards,
1991Stefan
Crewman 1991Stefan
Crewman
Posted: ‎2025-02-17 11:08 AM
706
thanks for the quick reply the problem is that unfortunately I don't really know much about modbus can someone help me
mkoermer
mkoermer Cadet
Cadet
Posted: ‎2025-02-24 03:04 PM
3
659
HI Stefan,
here the file - copy the infos in cycle Script.
Change the IP Adress from the Inverter and the Group-Adresses.
best regards
Michael
Fronius Solar Inverter.zip
1991Stefan
Crewman 1991Stefan
Crewman
Posted: ‎2025-02-25 01:17 PM
635
Hello, thanks for your help. Could you explain what I have to do in a little more detail? Unfortunately, I don't know much about it.
Kind regards,
Nagl Stefan
Pascal_Haltner
Pascal_Haltner
Cadet
Posted: ‎2025-03-29 11:09 AM
Thanks so much for the file 🙂 Now I have another question: The IP address needs to be adjusted. Which IP address should be entered for the inverter or the Spacelynk? The question also concerns the group address: which one does this affect?
Thomas_Rohde
Sisko
Posted: ‎2025-04-02 01:01 AM
Hello Pascal!
to "Which IP address should be entered for the inverter or the Spacelynk?"
The one of the inverter. The spaceLYnk needs to find the Inverter within the network.
to "The question also concerns the group address: which one does this affect?"
This depends on what you want to do with it. Or what kind of information the inverter provides are interesting for you.
In case you have a 4" Mini Touch then you are may interested only in the Energy-Values.
In case you are using the Wiser KNX App then you may want to see the energy flow.
In this case you need to link also the Power-Value with a dedicated group address.
In case you want to see the status of the inverter you need to link also this group address.
So it is pretty up to you or the requests of the project on what kind of group addresses needs to be linked.
One hint in case of group addresses ... please use virtual group addresses for values which does not need to be sent on the KNX-Side. Background, when you sent e.g. the powervalue on the KNX-Bus and there is no KNX-Device which acknowledge this telegram the you get useless telegram repeats on the bus.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Posted: ‎2025-04-02 01:03 AM
Hello Stefan!
Is it working now? Or any kind of questions left?
Feel free to come back 😉
Kind regards
Thomas
