Change Color on scheduller top bar
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Change Color on scheduller top bar
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2014-09-15 07:12 AM . Last Modified: ‎2024-07-15 12:05 AM
756
Is it possible to change color on scheduller / trending top bar?
Customer wants to change it for corporate integration.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
sesa299442
sesa299442 Schneider Alumni (Retired)
Posted: ‎2014-09-16 12:27 AM
733
Please check the application note AN006_Advanced techniques in visualization (it is available on this community).
There is described the process of css modification.
Just for example.
Go to Vis.graphics -> Edit custom CSS and write following two lines:
div.navbar-inner{color:#0ffff0 !important}
div.navbar-inner{background-image:linear-gradient(#000000,#ffffff)!important}
Changing the color numbers you will see the effect in the visualization.
Regards
T.
Posted: ‎2014-09-15 10:27 AM
Yes, you can do this via CSS.
Everything you need is to search what is the name of this bar If you want, I can show you changes I made.
sesa299442
734
Just for example.
Regards
T.
esteve_budia
Lieutenant
Posted: ‎2014-09-16 06:16 AM
Thank you again for your quick answer and correct.. I have been trying and everything is ok except the lateral colors that I could not find via firebug. I attach a pic with colors I would need o change.
4679
