AN041 Daikin HVAC Systems via CoolMasterNet
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • AN041 Daikin HVAC Systems via CoolMasterNet
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa288847
sesa288847 Schneider Alumni (Retired)
Posted: ‎2016-08-15 01:08 AM . Last Modified: ‎2024-07-14 11:54 PM
1241
Integration of spaceLYnk and DAIKIN HVAC with CoolMasterNet
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
AN041_Daikin_HVAC_Systems_via_CoolMasterNet.zip
Tags (4)
  • home automation
  • hvac
  • knx
  • modbus
Replies 5
sesa236725_brid
sesa236725_brid Schneider Alumni (Retired)
Posted: ‎2016-08-24 10:00 PM
Hi Jakus Hradeks ,
You are using CoolMaster along with SpaceLYnk to communicate with Daikin.
Can't we use SpaceLYnk directly with Daikin HVAC system , If not why.
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2016-08-24 11:39 PM
Hello Muppanna,
We can't use spaceLYnk directly with Daikin HVAC (and others) systems, becouse Daikin (and others) has their own internal communication protocol and this we don't know. This is reason why we need to use CoolMasterNet communication bridge. If you are able to obtain this protocol(s) and you are able to create scripts, ofcourse you can do it yourself without any bridge.
Regards David.
sesa236725_brid
Posted: ‎2016-08-25 01:49 AM
HI David ,
If the Daikin HVAC ( and other ) gives us the Modbus gateway , then can we communicate with spaceLYnk.
Regards
D E Muppanna
David_Navratil
Lt. Commander
Posted: ‎2016-08-25 05:53 AM
Yes, if Daikin (and others) provide this protocol, then yes.
Regards David N.
sesa236725_brid
Posted: ‎2016-08-25 10:04 PM
Hi David .
Thank you.
Regards
