New user - so many questions!
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • New user - so many questions!
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
TheMoebius
Crewman TheMoebius
Crewman
Posted: ‎2025-10-05 04:47 PM
377
Hi.  I've finally taken the plunge and ordered some C-Bus kit.  Been wanting to do it for years and as the house is being rewired I figured now is probably the time.  The only problem is there's hardly any info online.  I hope you can help me with some info on the following.
1) I have ordered 2x 5508D1D SpaceLogic 8 channel dimmers so I can dim LED spotlights.  I was thinking about adding some relays too for sidelights etc.  Will the two systems be compatible or do I need separate software/controllers etc?
2) How do I program the system using a PC?
3) Once programmed, does the unit store all the programming, or does there need to be a dedicated controller or computer permanently attached?
4) Does the ethernet interface offer different functionality than the plain old serial interface? (My home server has a serial interface so I can attach it directly)
Thanks so much for any help you can provide.  I'm used to programming PBXs but this is all new to me.
TheMoebius
Crewman TheMoebius
Crewman
Posted: ‎2025-10-08 02:59 PM
Nobody? 😢
aussie
aussie
Cadet
Posted: ‎2025-10-13 03:29 PM
310
1-one system for the two products that you wish to use.
2-Cbus commission software, Toolkit.
3-Stored "internally" (no need for third party).
4-not as far as i know.
Personally i would get a qualified installer to undertake this work. I assume that you are a sparky or engaging one to do the actual wiring?
TheMoebius
Crewman TheMoebius
Crewman
Posted: ‎2025-10-27 05:27 PM
Doing it myself mate.  Electrical Enginner so it should be handy enough.
