Interfacing Struxureware & Schedule Plus
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • Interfacing Struxureware & Schedule Plus
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
sesa96364
Posted: ‎2014-02-23 07:35 PM
7
2714
New features in Schedule Plus allow direct interfacing between Schedule Plus and Struxureware.
The attached document describes the configuration, benefits and features.
Replies 7
sesa145087_brid
sesa145087_brid Schneider Alumni (Retired)
Posted: ‎2015-03-26 07:28 PM
Hi Matthew,
This is really helpful. Thank you very much!
Posted: ‎2015-03-29 04:03 PM
Thanks Matthew.
sesa145087_brid
Posted: ‎2015-08-06 10:52 PM
Hi Matthew,
We are testing this application now. But we met an issue, that the control command have a like 10 seconds delay. I have already set the Poll interval in Smartstruxure to 1 second, but it didn't change. Have you ever experienced this? Thank you very much!
sesa96364
Posted: ‎2015-08-13 11:32 PM
Hi Andrew,
I just managed to test this again with SBO 1.6.1 and I don't see any delay.
I am using the web services scripting method, I notice you mention setting a poll interval. Are you using a different method of configuring SBO?
sesa145087_brid
Posted: ‎2015-08-31 02:48 AM
Hi Matthew,
Sorry I made a mistake before. I also got the issue request from others. Here is the script I used. Looks like no matter what is the control value I have changed ( SchedulePlus.CBusSetLighting(254,56,1,1) or SchedulePlus.CBusSetLighting(254,56,1,0) ), the value I get is unchanged ( SchedulePlus.CBusGetLighting(254,56,1) ). So I don't know whether there is something wrong. Here is the entire script:
Webservice SchedulePlus
Numeric Output N253A55G47O1
N253A55G47O1 =SchedulePlus.CBusGetLighting(254,56,1)
Or do you have the detailed specification for the function instead of just a list and data type?
Andrew
Pradeep
Lt. Commander Pradeep Lt. Commander
Lt. Commander
Posted: ‎2015-12-08 01:56 AM
Hi Matthew / Andrew,
Is the EcoStruxure Webservices feature is enabled by default in Schedule plus software? or is it a separate part reference & license ? In SBO we need to add the EWS license (Separate part reference) to the base software. Please advise.
Pradeep Viswanathan
sesa96364
Posted: ‎2015-12-08 09:02 PM
I have received comments about SBO lacking in performance when using scripting to access web services.
The solution for this is being documented at the moment and will be available soon, and will resolve any performance issues between S+ and SBO.
I'll publish what I can once I have some beta test results.
