Does SE have a dual tech sensor in C-Bus series?
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • Does SE have a dual tech sensor in C-Bus series?
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
sesa176440
sesa176440 Schneider Alumni (Retired)
Posted: ‎2014-04-24 08:38 PM
1356
We are facing challenge from our competitor on dual tech sensor. Main contractor do not concentrate on functionality of dual tech sensor only. Installation cost, material cost and cable cost are main consideration too. Extra conduit and cable will be installed if our dual tech sensor is used.
Can we change the power supply of dual tech sensor from 220Vac to C-Bus control?
sesa96364
Posted: ‎2014-04-28 08:35 PM
Clipsal have a dual tech sensor (Ultrasonic & Passive infrared) for occupancy detection, part number 752.
This can operate as a 3 wire device on 240VAC or it can be connected to a C-Bus auxiliary unit (L5504AUX) using a common collector output on the sensor.
Technical details can be found here:
http://updates.clipsal.com/ClipsalOnline/Files/Brochures/A0000261.pdf
Installation instructions can be found here:
http://updates.clipsal.com/clipsalonline/Files/Brochures/W0001560.pdf
Replies 4
sesa96364
Posted: ‎2014-05-21 06:43 PM
1291
Can you be more specifc in C-Bus interface ?
sesa96364
Posted: ‎2014-05-22 05:51 PM
Figure 4 of the installation instructions show pins A1 & B1 of the sensor are connected to the C-Bus auxiliary unit. These correspond to inputs A1 & B1 of a C-Bus auxiliary unit.
When the sensor is triggered a pulse will be sent to the C-Bus auxiliary input.
The C-Bus auxiliary channel would typically be programmed as a re-trigger timer, however the auxiliary channel function can be any function to suit the customer requirement.
Mr_C
Ensign Mr_C Ensign
Ensign
Posted: ‎2015-03-11 05:32 PM
Additionally their are a range of C-Bus Occupancy Controller Range consisting of the following controller models
5752PP/1R Occupancy Controller, With 1 Relay Output
5752PP/2R Occupancy Controller, With 2 Relay Output
5752PP/2R/2D Occupancy Controller, With 2 Relay Output, 2 DSI/DALI/0-10VDC
This Range Supports the following Sensor Offer
752/CP Passive Infrared Occupancy Sensor, Ceiling Mount, 360deg
752/WP Passive Infrared Occupancy Sensor, Wall Mount, 110deg
752/CU Ultrasonic Occupancy Sensor, Ceiling Mount, 360deg
752/CD Ultrasonic/Passive Infrared Occupancy Sensor, Ceiling Mount, 360deg
Schneider Electric Australia PTY
