Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
Merhabalar, mevcutta kullandığımız bir dimmer sisteminiz bulunmaktadır. Bu sistemi birden fazla noktada yönetmek istiyoruz gerek ışık şiddetini gerekse açma kapamayi. Bunu yapmak mümkündür. Mümkünse nasıl bir bağlantı şeması kullanmamız gerekir. Bana bu sistemi sanki dimmer Vavien ile yapabilirim gibi geldi ama mevcut sisteme herhangi bir marka vavien anahtar ve potansiyemetre ile yapabilirmiyim, yoksa vavien anahtar bağlantısı ile sadece açma kapamayimi yapabilirim. Bu konuda bağlantı şeması ile bana destek olabilirseniz çok sevinirim. Desteğiniz için teşekkür ederim
Hi there,
If you are interested in controlling and monitoring lighting, you will require specialised products to achieve this.
In this circumstance, this means that you will not be able to use a standard electrical dimmers to achieve this as they have no way of communicating their status or control capabilities to an external system.
This Forum focuses on SpaceLogic C-Bus solutions which are predominantly installed within the Australian/Pacific region meaning that the solutions we suggest here may not be relevant to your location.
There are a number of environmental aspects that will need to be taken into consideration before an appropriate solution is selected. Information such as the amount of circuits requiring control, physical size of the job, particular budgetary requirements, new installation vs existing etc will assist in determining the appropriate solution.
It will likely be best to approach a local sales representative to discuss your options should this be something that you wish to pursue
