Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
Posted: 2021-07-12 05:16 AM
Hi Team,
We are looking a Lua Script for NAC/SHAC for Daikin VRV Air Condition System Operation via Modbus RTU.
Kindly share the asked script.
Digital Technologies.
You would require a JSON file for modbus integration. (Modbus tcp or modbusRTU would both use the same json file)
Sorry to say I am not aware of a JSON for this ( if there is a JSON it probably is not "tested and validated" on a live system).
I think from looking at some Daikin Specification docs that is is quite complicated as it requires supporting alot of bitmasking values.
The Docs suggest that 1 card is used for up to 16 units.
