CRESTRON INTEGRATION
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • CRESTRON INTEGRATION
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
Posted: ‎2014-06-03 04:23 AM
1091
Hi every one Hope all are doing good. I am Suyog from India in one of my project i am integrating Crestron with C-Bus.I am able to control all the relay and dimmer modules through Crestron App but facing problem with C-bus fan module and curtain module.As in Crestron i can control a group address but when it comes for curtain module  i have one group address due to which i am just able to control open and close of the curtain, how can i get a stop command on the Crestron app.Same is the problem with fan module also i can controlON/OFF only no medium or low speed can be controlled through Crestron..
Did any one else face the same issue, kindly support ....
sesa96364
Posted: ‎2014-06-03 08:11 PM
1
1032
Shutter/Curtain Controller:
There are 3 recommended ways to control a Curtain controller on C-Bus.
  • 1 button control:
          Toggle, send a message to C-Bus to set the group address to 98%
          This will cause the curtain controller to change direction, a subsequent press will cause it to stop
  • 2 button control
          Open/Stop, send a message to C-Bus to set the group address to 99%
          Close/Stop, send a message to C-Bus to set the group address to 1%
  • 3 button control:
          Open, send a message to C-Bus to set the group address to 100% (on)
          Close, send a message to C-Bus to set the group address to 0% (off)
          Stop, send a message to C-Bus to set the group address to 2%
From your description I assume you are sending an on & off message, this will cause the curtain controller to open fully, and close fully.
Adding another button to crestron screen to send a command to go to 2% will cause the curtain to stop.
Fan Controller:
When configuring the fan controller in Toolkit you can select the number of speeds:
  • 1 speed (off, high)
  • 2 speed (off, medium, high)
  • 3 speed (off, low, medium, high)
After selecting the number of speeds you can set the lighting level threshold between each speed.
By default, the thresholds for a 3 speed fan controller are 34% and 67%.
If the lighting group address is set to 0% the fan will be off.
If the lighting group address is set to any level from 1% & 33% the low fan speed will be set, from 34% & 66% is medium fan speed, 67% and above it high fan speed.
From your description I assume you have a lighting on and off button.
Adding another 2 buttons will provide the low and medium fan speeds.
I recommend the low button set the lighting group to 25%, and the medium button set the lighting group to 50%.
sesa96364
1
1033
  • 1 button control:
  • 2 button control
  • 3 button control:
Fan Controller:
Posted: ‎2014-06-04 02:06 AM
Dear Mr.Matthew, Thanks for the extended support .Shall try doing the changes in programming.
