Vw3A1111 connected to ATV320 fail TTC
  • Industrial Automation
  • Solutions for Motor Management
  • Vw3A1111 connected to ATV320 fail TTC
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Jerry.Chen
Crewman Jerry.Chen
Crewman
Posted: ‎2023-08-31 07:49 PM . Last Modified: ‎2023-08-31 07:50 PM
2
1444
TTC error after connecting ATV320 V2.9 IE34
  • Drives & Motor Control
Ahmed_Alzafer
Lieutenant JG Ahmed_Alzafer Lieutenant JG
Lieutenant JG
Posted: ‎2023-09-11 08:04 AM
hello Jerry
Both the ATV320 VFD and the VW3A1111 keypad firmwares have been upgraded to support compatibility. (6-2019)
Firmware versions required:
ATV320  V2.9IE37#3
VW3A1111  V2.0IE53
Earlier versions are not compatible.
Note: Early versions of the ATV320 catalog included the VW3A1111 keypad by mistake, but was removed from the Sept 2018 catalog.
Jean_Commeignes
Administrator Jean_Commeignes Administrator
Posted: ‎2023-09-06 02:09 AM
@Zirwa , Could any Vw3A1111 or ATV320 expert adress this issue?
Jean COMMEIGNES
Schneider Electric Community Manager for Power & Building
Ahmed_Alzafer
Lieutenant JG
hello Jerry
ATV320  V2.9IE37#3
VW3A1111  V2.0IE53
