Motor test
  • Industrial Automation
  • Solutions for Motor Management
  • Motor test
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
salm11
salm11
Cadet
Posted: ‎2022-09-22 11:02 PM . Last Modified: ‎2022-09-23 10:54 PM
2048
Motor test
Hi, I,m a newbie intern currently working in fmcg plant. Here we got a problem in one of our induction motor which instantly stopped working, since motor is not much older our engr. first check mcc circuit and relays but everything was ok. we replaced the motor at the spot, now i wana know how i can check motor completely, means its winding, connection box etc. I also found a blog about motor testing(1)   but still i,m confused with this motor box design, i.e star delta connections.
Refrence(1) https://meterreviews.com/how-to-test-motor-with-multimeter/
  • Training & How to
Delcho_Penkov
Lieutenant JG Delcho_Penkov Lieutenant JG
Lieutenant JG
Posted: ‎2022-10-07 06:49 AM
Hello @salm11 ,
Basically you need to check the connections for the motor. I would be surprised if the motor terminal box embeds the contactors for star-delta start, this shall be a bit upstream the circuit. Before to test the motor completely it is worth to look around and try to identify what might be the reasons it stopped.
By the way , how exactly happened that it stopped?
Best regards,
Delcho_Penkov
Lieutenant JG
Hello @salm11 ,
Best regards,
