Posted: 2021-11-18 06:31 AM
How to overcome from Partial discharge in MV motors with help of MV drives ?
Posted: 2022-02-16 04:54 AM . Last Modified: 2022-02-16 07:17 AM
The partial discharge on the motor side is due to spike voltage due to PWM signal of drive and cable length. Multilevel waveform limits these constraints.
To have a better understanding to the motor insulation issue, you can find the attached document.
Presented with LV motor can be easily extended to MV
